Thread Tools | Display Modes |
Fix the bending and waving images when playing beta and VHS tapes on your old TV
Here are some Horizontal AFC schematics for various sets from the 1970s with
slight additions that may be helpful in stopping the flag waving or jittering you see when you play beta or VHS tapes through your vintage TV set. https://www.dropbox.com/s/1fw8311noq...for%20VCRs.PDF These are not absolute by any means but are suggestions that may help you modify your sets H AFC so it is more stable. Cliff |
Since this thread seems to have arisen due to a PM I sent Cliff asking how to deal with the problem on my TV, I thought I'd post how I wound up solving it (or at least getting it as watchable as I could, given the parts I had on hand).
Here is part of the horizontal section of the schematic for my Zenith C1415 set (16C20 chassis). I have circled the two components I changed in dark blue: I noticed that if I disconnected C47 and C48, the picture became quite stable while watching VHS tapes (with only a very slight bend at the top, depending on where I had my horizontal hold set). So in order to leave everything connected and still solve the issue, what I ended up doing was making the C48 capacitor a very, very small value and making R70 a very, very large value (currently, I have less than 10pF for C48 and more than 1M-ohm for R70). An interesting side effect is that the horizontal hold locks in over a much wider range, now. I can actually sort of use the horizontal hold as a centering control now, and somewhat control the degree of bending at the top of a VHS signal. EDIT: I might have overdone it, haha. The picture tends to bend a bit with sudden changes in brightness with an otherwise good signal, so I think I have a little more experimenting to do. Last edited by jmetal88; 06-19-2013 at 01:12 AM. |
It's obviously a common problem, or the OP wouldn't have had five pages of examples for fixing the problem... |
DVD player output is crystal controlled, is generating perfect sync locally (instead of playing it back), and does not have any horizontal phase jump. |
How much of an effect has it had on the G1 voltage? (-3.5v) and what happens with a no signal condition? You know all snow..... or a weak signal?
EDIT: I might be imagining it, but I think my set somehow started having more reasonable contrast since doing the mod. EDIT 2: Oh, and also I changed the values again since the first post. It's much less 'drastic' now, and I just tweaked the values enough to get a stable picture from a VHS source, but not enough to totally remove the bend at the top. EDIT 3: Actually, I don't think I was reading the voltmeter quickly enough. The voltage drops when I hold the probes in place, but it starts out around -3.9V before it drops. Last edited by jmetal88; 06-20-2013 at 02:25 AM. |
I just feed the VCR video signal through the digital TBC in my DVD recorder...
Never had issues with my Beta decks before.
Ideally, I'd like to get one of those DVD recorders with a pass-through TBC and return my set to the original configuration, but I don't have nearly enough spare cash to do that right now. I think I'd prefer a standalone TBC, though, since I think that would help a lot more with recording tapes to my computer (even though they're a lot more expensive). |
When I do captures for DVD transfers, I usually use a SVHS VCR with a line TBC (true Time-base correction) to correct horizontal jitter and an external full-frame TBC (really just a frame sync/buffer as my unit does little jitter correction) to clean up the sync (front/back porch, color burst, etc) and output proper RS-170a to the capture card. It also provides a stable continuous sync signal to prevent frame dropping. A popular DVD recorder with pass-through TBC is the Panasonic DMR-E10. Some of the JVC DVHS machines also have pass through TBC functionality as well. |
I always thought of a TBC as only cleaning synch issues and not the video that makes it to the screen...That site stretches the definition I've always had of a TBC. I mostly use a Toshiba D-VR5 for elimination of flag waving/ bends at the top of the screen on my tube sets. I feed it S-video from my JVC HR-S3912U SVHS-ET deck(the Toshiba is a VCR/DVD recorder, but I don't like or use the tape section of it). I also have a Panasonic DMR-E80H that may have a TBC, but the current state of my system wiring prevents me from easily testing that. I do have a NEC brand DS8000U mkII SVHS deck with a three setting "Digital NR" that improves video noise issues(I can't find any info about this deck online). It does get motion issues at it's highest setting, but the lower settings seem to get the job done without doing that to an objectionable or noticeable extent. I almost never transfer video tape to digital formats...As I prefer to watch my tapes on a CRT TV with a tape deck(In fact aside from my computers, which I rarely watch video on, I only use CRTs for the video I watch). Also most of my tapes are first gen time-shifts made on decks I still own and keep working, so anything more than synch correction is not all that noticeable or important to me.
Tom C. Zenith: The quality stays in EVEN after the name falls off! What I want. --> http://www.videokarma.org/showpost.p...62&postcount=4 Last edited by Electronic M; 06-23-2013 at 10:08 PM. |
Encountering issue on my ctc-38. Played one tape without an issue then the next one had massive bending at the top, tried a third and same thing. Horizontal AFC circuit is a bit different than the zenith earlier in this thread - any ideas which parts to mess with ?
I've found multiple DVD recorders, and a stand alone TBC at thrift shops and garage sales usually for less than 10$. If you can't afford a new item go hit the pavement and look for a used one.
Thanks for the tip re: flagging with VHS
My XL100 does this with every deck i have and I'm going to dig in and see what can be done. |
