Old 06-18-2013, 01:27 AM
RCA Chassis KCS88K , anyone have any info on this?
I just thought i'd ask since some of the guys here know a lot about chassis and could shed some light on it , i checked the crt and it is real good.
mike
Old 06-18-2013, 09:22 AM
mike
The set was RCA's first, re-design models. IIRC, it was the first RCA, to use an audio output tube voltage divider. That model was a lot simpler, than the previous models. As a result, they're easier to restore.
Yours is a UHF model, that had a cascode tuner and a better AGC circuit. They work well, when restored.
Old 06-18-2013, 10:51 AM
audio output tube as a voltage divider - why ?
mike
Old 06-18-2013, 11:42 AM
mike
Output stage does double duty as a B+ dropping resistor. Saves cost of a large power resistor, reduces parts count.
Old 06-18-2013, 06:12 PM
Also slightly less power consumption.
All manufacturers seemed to use it alot. Just about any set that used a 6AS5, 6W6, 6Y6, 6BF5, 25L6, 12L6, as an audio output.
Also reffered to as stacked B+.
Old 06-18-2013, 01:35 PM
Reminds me of one that is rotting about half a mile from the family cabin.
Old 06-18-2013, 02:03 PM
Similar to my family's first TV. That set logged a lot of hours over the years!
http://antiqueradio.org/MyFirstTV.htm
Phil Nelson
Old 06-18-2013, 02:10 PM
compucat's Avatar
compucat compucat is offline
1949 Motorola 9VT1
Those RCAs from the Fifties really seem to be built for long service life.
Old 06-18-2013, 08:24 PM
Hell, someone over in one of the color TV forums is restoring a set almost as beat up as that one... http://www.videokarma.org/showthread.php?t=258006
Old 06-19-2013, 01:31 AM
I wonder who that nut is? LOL.
If I had not had the misguided idea when I was around 10 years old to smash the CRT neck to discharge that lethal high voltage that was sitting there all those years, I'd have dragged it home and started messing with it years ago..... I did take most of it's tubes though.
Old 06-19-2013, 08:31 AM
The rusty model shown, is the slightly newer model.
It might be a KCS92, which was simular, but had 90 degree sweep and a few changes in the tube lineup.
Both models were the first RCA's to use PC boards in the IF and audio circuits.
Old 06-19-2013, 02:24 AM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
And doing a "bang up" job of it too.
Old 06-18-2013, 09:48 PM
truetone36's Avatar
electronics packrat
That model's from 1954, IIRC. I have two of them. One's in fair shape, and the other looks like the one Electronic M posted the pic of. Both are missing the channel selector knobs, however.
Old 06-19-2013, 02:03 AM
the one that is rotting away has a chanel selector knob , theres your chance of getting one
mike
Old 06-19-2013, 11:05 AM
Funny, I don't recall seeing any PC boards in that RCA, though it is so full of leaves I could imagine not seeing it under all that.
