Sonora 302 restoration
I wanted to squeeze in one last major refinishing job before the cold weather arrives. eenie meenie miney mo - this Sonora 302 is it.
Here's the thread from when I got it last year: http://www.videokarma.org/showthread.php?t=254990 ![]() It's an interesting design that uses a variable capacitor for continuous tuning. Looks very easy to work on ![]() Over the last year, thanks to some reference photos from Eric H and a lot of luck, I was able to track down a complete set of knobs including the continuous tuning channel plate! ![]() This is easily the crappiest cabinet I've encountered. It's a basic plywood box with little bracing and mismatched veneer. As you can see, it's warped over the years especially on the side with the missing brace and the top. ![]() The top is also stained and nasty looking. ![]() I started by removing the brass trim, safety glass and metal bezel. Then moved on to reinforcing the cabinet. ![]() I used a sturdy piece of oak across the top. That's better! I later had to cut out an arch otherwise the CRT wouldn't fit inside. ![]() Here's the cabinet after stripping. I also used a little bleach on top to remove the worst of the staining. As you can see, it's mahogany. ![]() As for this side, I'm not sure what it is exactly. Low grade mahogany ? Cherry ? It sure doesn't match the top or other side. ![]() All patched up, grain filled and ready for some color ![]()
I sprayed it up in the attic using a coat of Mohawk "Red Cherry/Mahogany" follow by "Brown Mahogany".
I discovered the metal bell of a 16GP4 makes a great spraying stand ![]() ![]() I though I'd be repainting the bezel but it cleaned up very well. ![]() I spent a few hours polishing up the brass control panel then coated with lacquer. ![]() ![]() And that's that! It turned out much better than I expected in the end. I'll probably get around to the electronics over the winter. Right now, I have a Dumont RA113 calling. ![]()
I enjoyed your vid Bob and these pics too. That set really came out beautiful! You turned a set that you'd might not take notice of become a real jewel. You have to love the maroon and gold colors they used back then. Very rich combination.
Joe |
Very fine job. That panel is very low grade mahoganny.
You did a great job on it.... Bill Cahill
"Tubes are those little glass things that light up orange unless there is a short.. Then they light up all pretty colors..." Please join my forum. http://www.tuberadioforum.com/ |
Beautiful job Bob, as always.
