Old 12-22-2013, 12:58 AM
Working on a RCA KCS72M
Hi all. I've been working on a 17" metal table model RCA KCS72M I got from miniman a few years back.
I've been working on it without a schematic as an exercise in refining my troubleshooting skills.
After about 90% recap I've hit a snag...I think the yoke is bad.
My first clue was when unplugging the yoke brought the HV up from 0 to 10KV.
My second clue is that if I use the yoke and CRT of my Telematic test jig I get about 12KV of HV and a decent picture (as long as I can keep it in synch).
The original ohms out to about 23.5ohms and the test jig yoke ohms out at around 14 ohms on the horizontal windings.
The numbers on the original yoke are 971385-2 274243 c14. Anyone know the numbers of any valid subs for the original yoke.
Also I've never encountered a bad yoke before so tell me if my logic seems wrong.
Old 12-22-2013, 02:14 AM
you should check the doorknob cap too just to be sure, if it is showing a picture with the test jig I would jump to the same conclusion you did
Old 12-22-2013, 02:40 AM
Your theory makes sense however there may be some caps inside the yoke, it's possible (tho unlikely) one of those could be shorted and killing the HV.
Old 12-26-2013, 11:44 PM
Tubejunke's Avatar
I have not seen capacitors inside of yokes, but I have seen resistors hidden underneath the cover.
Old 12-22-2013, 04:00 AM
If it is a bad yoke, maybe you can swing by Rockford, IL and pick up this one for parts ?
http://rockford.craigslist.org/atq/4148231134.html
Old 12-22-2013, 10:33 AM
971385-2 crosses to Thordarson Y-42.
Old 12-22-2013, 12:31 PM
I'm fairly sure that there is no door knob cap in my set as I don't recall seeing one in the HV cage and this set uses a glass CRT.
I already checked the yoke for a cap and the only one in there, a pico-farad range ceramic tube, measured open on the 2M scale of my DMM...I could always hit it with 450V from my heathkit C-3 and see what happens.
For a while I was able to get some HV and a ~1" tall horizontal line on the set by plugging the yoke in such that there was loud arcing in the socket (ie yoke almost unplugged).
I'll have to consider both options as I don't want another cabinet to have to dispose of, but then again the CRT in mine is below the good range on my tester without bumping up the filament voltage so a better CRT might be worth while.
Old 12-24-2013, 02:58 PM
The yoke plug has a jumper between pins 6&7. It's used to supply B+ to the chassis.
How do you get the chassis to produce HV, without the yoke plugged in?
Old 12-22-2013, 08:48 PM
Tim's Avatar
Tim Tim is offline
971385-2 crosses to Merit MDF-89 and RCA P/N 77697.
Playthings of the Past lists the RCA.
9998-905 TELEVISN RCA 77697 YOKE WITH OCTAL PLUG, RCA 971385-5, 2746350-3, LOOKS NEW.. 1 0 0/0 0 0/0 0 0/0 9.00
http://www.oldradioparts.com/2a23ffl.txt
They are closed until 1/12
Tim
Old 12-24-2013, 06:02 PM
That jumper circuit was open EVEN with the yoke connected so I've had it jumpered since early on in my work.
I need to find a schematic for it eventually as I want to investigate using the RCA video jack on the back as a composite video input.
Old 12-26-2013, 11:20 PM
Penthode's Avatar
Penthode Penthode is offline
Before condemning the yoke, have you done some basic visual and DC resistance checks around it?
I am not a betting man but if I was I'd wager that with a bit of examination you'll find what is wrong with the yoke.
Old 12-27-2013, 01:55 PM
Most of the stuff around it looks to be in good shape. I presently do not have a schematic so even if I did resistance checks I likely would miss any problem encountered as I don't know what the nominal expected resistances between points are.
Dave G. has offered to send me the schematic so until it arrives or I get a new yoke I'm leaving this one on the side so I can focus on other projects.
Old 12-28-2013, 12:08 AM
Quite often there is a mica cap inside the yoke across the horizontal coils. This set has a 91pF in series with a 1,000 ohm resistor.
Here's the schematic from Riders vol 10. There are several chassis revisions and this is the earliest. http://www.flickr.com/photos/70039806@N00/11598231834/
Old 12-29-2013, 08:40 PM
There's a bit of difference between the KCS72 and the KCS66, schematic as shown.
The KCS72 must be the el-cheapo model, that year.
I have two 21" consoles with that chassis. It uses the older type penthode tuner and a 21mhz IF strip, which was strange, as RCA was one of the firms, that changed to 41mhz IF's early on.
The KCS72 chassis used a 5U4 and 5Y3 rectifier, power supply, where the KCS66, used a selenium rectifier and voltage doubler power supply.
The KCS66 uses a 41mhz IF and a cascade tuner, plus four stages of IF.
The horizontal sweep should be very similar. Yoke is the same.
Spellcheck didn't like the tuner description, regarding the RF stage.
Old 12-28-2013, 05:54 AM
danny danny is offline
Danny
Hi if the b+ interlock has failed it might be worth checking the plug and socket ! disconnect it and hard wire it. Also have you done a ring test on the yoke to see if it has shorted turnes . If it has shorted turnes then i would dismantle it to find the offending short and re insulate it. Ive done this in the past with total succsess.
Danny
