Old 03-31-2014, 03:14 PM
Zenith CC2 avanti horz chassis
Noticed lately that my avanti picture is not as sharp as I think it should be. The CRT test strong picture peak is working, the focus pot has to be turned fully one way and never really goes into focus and out again. I do not recall if its fully CW or CCW. the plan is to pull the back and get my simpson 260 on the focus pin (it goes up to 5kv if that is not high enough I can use my HV prob) and 1st see if its on the low or high side of the pot. From there will have to see what next. I did buy a new focus voltage divider just in case it is the problem.
the pot works as far as turning changes focus just seems to run out of range.
I wonder if the CRT socket/pin could be an issue? I have seen corrosion on those before (at least on some color crt's).
Old 03-31-2014, 03:19 PM
I can see a 4.7 meg resistor 2 watt resistor to ground, if that has opened up some I imagine the focus voltage could be too high, hope that is the case, will know for sure when I see which side of the pot the wiper is turned to.
Old 03-31-2014, 04:32 PM
If the BIG HV divider has drifted high you can compensate for it by adding series resistance to 4.7M 2W. I did that on a CCI hybrid I own, and after it drifted a couple of more times in the following year(which caused me to bump up the added series resistance), it found a stable good point that it has sat on for the last three years.
Old 03-31-2014, 05:14 PM
well its too high, the focus pot is max CCW min voltage on the pin. So I will start with the 4.7 meg to ground, if that is not it I have a new divider to try.
Not really looking forward to getting to it since the service saver is pretty well blocked off by the fiberglass pedastal.
Old 03-31-2014, 06:57 PM
Does that set have the 800-860 focus divider. IIRC, the kit always included a 4.7 meg resistor, in case, the focus wouldn't adjust properly.
Old 03-31-2014, 07:37 PM
600M with tap at 70M I have 63-9895, no resistor in package. I can't imagine how far off the 4.7 meg to ground would have to be to have an effect on the control. Pot is a 15 meg. as mentioned I could prob put a 100meg resistor across the 70 meg IF it has gone high.
Old 03-31-2014, 04:08 PM
Old 03-31-2014, 11:12 PM
Some versions of that chassis used an NTE526 tripler that contains the focus divider inside the tripler. On sets that have the seperate tripler and focus divider, it is possible to replace the original tripler and focus divider with the newer NTE526 tripler.
