Old 06-17-2014, 06:20 PM
Bill Cahill's Avatar
Super Moderator
Smile Need help with my 16" round tube Admiral tv
First, I lost the schematic. It's a straight tv only. Console with half doors. Don't remember model number. Secondly, can somebody help me with a good correct replacement power transformer for it? Either new, or on a chassis??
Please help, guys. Thanks.
Bill Cahill
Uses single 5U4 rectifier tube on chassis. Power transformer is completely under chassis.
Please join my forum.
Old 09-01-2014, 02:09 PM
Super Moderator
Post
Finally, I found the Chassis number to the set. It is 21D1. I desperately need the power transformer for this set, and, schematic. The rectangular version isn't very close. Can somebody please help me?? Maybe you have a chassis with a good transformer?? Or, can someone find me a new old stock replacement?
Thank You..
Bill Cahill
Old 09-02-2014, 09:37 AM
earlyfilm's Avatar
Eternal Member
Originally Posted by Bill Cahill View Post
. . . . 21D1. . . . I desperately need the power transformer for this set, and, schematic.
The schematic is the last schematic in the 26 page 21D1 Rider manual:
http://www.earlytelevision.org/tv_sc...s_postwar.html
Jas.
Old 09-02-2014, 01:15 PM
Findm-Keepm's Avatar
Followin' the Rules...
Working backwards, both Admiral part number 80C26-1 crosses to the Merit P 2867.
Thordarson lists the original transformer number for the 21D1 as 80C26-1, and crosses it to a Thordarson 26R71. The 80C26-2 carried by Play Things of the Past also crosses to the 26R71. The 80C26-2 is listed as used used in the 20V1 and 20T1 chassis.
I have neither, and can't go any further.
Cheers,
Brian
USN RET 22YRS (Avionics/Cal)
Old 09-02-2014, 01:37 PM
Super Moderator
Unhappy
According to what I can find out, the Thordarson transformer is for a set that used a 5V4 damper. My Admiral uses a 6W4 with an isolated hv winding for the filament, due to cathode being tied to it like RCA did.
Who was the big internet company that carried new old stock tv transformers?
I was told to call Mark Oprat. I did. He was friendly, but, doubted he'd have one, and, said he couldn't look for 3-4 weeks. He said to talk to Gary at play things of the past, and, he didn't even want to take the time to look up part numbers. He said I must have all the factory data, including exact sizes, ratings, etc....
Not having much luck here...Hasn't anyone got a spare set they could part out??
Old 09-02-2014, 01:58 PM
All of the transformers you have listed and the Thordarson have 3 secondary windings - B+, 6.3V and 5V. No difference between them that I can see.
Look at the schematic on ARF (page 26 of 26) - the damper filament is fed by the power transformer.
Cheers,
Brian
Old 09-01-2014, 06:43 PM
nasadowsk's Avatar
Damn does run fast…
Got a part # on the xfmr?
Old 09-02-2014, 07:26 AM
Super Moderator
Post
Actually, I have several part numbers. Here they are.........
Merit P 2867
Stancor P 8164
Triad R 66F35
Hope you can help. Thanks.
Bill Cahill
Old 09-02-2014, 07:36 AM
Play Things of the Past lists two Admiral TV power transformers - you didn't give the original number (which would help!), but the two they list are:
80B58-1 and 80C26-2
Also, what are the secondary windings? Sometimes a tranny with an additional winding will work, you just don't need/use the additional winding.
Or, one without the rectifier filament winding will do if you convert to a silicon diode.
I've got Triad, Thordarson, and Merit Transformers, but need more info to see if any of mine might even be close.
Cheers,
Brian
Old 09-02-2014, 07:59 AM
Super Moderator
Post
The part numbers I gave are exact replacements. John didn't give me the Admiral part number.
No, I don't wish to go to silicon rectifiers.
Old 09-02-2014, 03:48 PM
According to the schematic, the 6W4 damper tube filament is in parallel with all the other tubes - no separate filament winding
Old 09-02-2014, 04:01 PM
So apparently Bill's is not really a 21D1 chassis? Seems like that chassis number should be stamped on the back side of his chassis.
Old 09-02-2014, 04:51 PM
After jogging the old memory cells, i don't recall ever seeing damper tubes such as 6W4, 6AX4 etc. using a dedicated heater winding. They had adequate H-K breakdown rating and ran the heater off the common 6.3V winding.
(6W4 does not have the heater tied to the cathode. )
Old 09-02-2014, 05:46 PM
I suppose there's a possibility that at some point someone subbed a non original transformer with an extra damper filament winding.
Old 09-03-2014, 07:49 AM
Super Moderator
Smile
Well, I could be wrong on the Admiral, then. Been awhile since I've looked at it.
But, RCA sure did have a separate winding for the 6W4 on their sets. Look at the schematics for the later 9T246, and, the KCS 47.
Thanks for the help, guys. I'm waiting for a replay from one company on both this transformer, and, the one for my RCA KCS26A.
In the meantime, I called a dealer in Livonia Michigan, whom, while it's doubtful he has the parts, remembered my old boss, Craig W Knox, being there occasionally to buy parts many years ago... He even remembered our shop name, Rainbow Television Service... Sure miss Craig. He's the best boss I've ever had.
Bill Cahill
