Old 07-08-2014, 08:25 AM
Rca vcr
there is one of these local to me, reminds me of the 1st VCR I ever owned. I have never worked on a VCR, are these a problem to repair?
Old 07-08-2014, 08:36 AM
Could easily be, because of availability of replacement parts, especially the belts and other rubber drives.
The early models are highly mechanical and extremely complicated. Plus, there has to be ten times, the electronic parts, compared to the newer ones.
Old 07-08-2014, 08:39 AM
prob before SMT, saw an older thread (after posting this) on one. Perhaps the owner can chime in on how his is holding up.
Old 07-08-2014, 11:27 AM
jstout66 jstout66 is offline
I had that model and gave it to Walter Beers. Mine "kinda" worked... I think it just needs a good cleaning and belts. Yes.. they are built like tanks and more complicated than a "modern" one. Depending on how it was stored ( hopefully in a climate controlled environment) it may work as is, or just needs belts. Moyers would have the parts/belts for that.
Old 07-08-2014, 04:44 PM
good to know, Its local so if nothing else can check it out.
Old 07-08-2014, 08:53 PM
I would grab it if its price is low, at least. I have that same model as in your picture (VBT-200), RCA's first consumer VCR. They need something like seven belts at a cost of $50-60 perhaps, but I am going to do the work on mine before too long. I got two Sony VCRs from that same time period working recently by doing little more than replacing belts and idler tires and lubrication, so these early Matsushita-built machines may be just as durable.
Old 07-08-2014, 09:00 PM
Gunslinger Gunslinger is offline
Early VBT200's needed the addition of a small metal plate to hold down a relay rod.
Old 07-09-2014, 07:34 AM
Ed in Tx's Avatar
Ed in Tx Ed in Tx is offline
Zenith Walton My 1st TV
Don't forget the sensor bulb!
Old 07-12-2014, 11:34 PM
Thank you for posting that tip, I hope I remember it when I get to repairing my two early RCA VCRs.
Old 07-15-2014, 08:42 PM
Blast's Avatar
Blast Blast is offline
blast, blast...
I've got the Quasar branded version of that. It was working 5 years ago when I put it in the closet. No use for it but, hate to get rid of it.
