Hickok 209a v.t.v.m.
Just wondering if anyone here has one of these and/or has brought one back from the dead. I am lucky enough to have one decent shape with both the AC probe and the correct DC probe as well. That's a HUGE plus from what I hear.
Anyway, nobody has been inside the thing as far as past repair other than changing the twin D cells for resistance measurements. But the meter is frankly all out of whack. I haven't seen a function yet that it is even able to begin to take a measurement as some functions and ranges cause weird mid scale meter deflection or like the +DC function slams the meter to the left. I did find a questionable rectifier between the two that it has, but adding a better one didn't change anything. I'm guessing that like most things that old (early 50s I think), the caps have got to go. That's probably what it will all boil down to. Luckily, there only seems to be a few caps in the unit. So maybe it won't take much to bring back what is supposed to be one of the best bench VTVMs ever made. B.T.W., I have downloaded the user and repair .pdf files. I don't think that they have calibration instructions which I would like to get if anyone has them.
"Face piles of trials with smiles, for it riles them to believe that you perceive the web they weave, and keep on thinking free" |
OK, thanks JT.
I found out something very interesting in that link that jr_tech gave me. It seems that the D cells for the resistance functions are positively grounded. A person on that forum was having some of the same issues as I am having, being the meter slamming to the left in various functions. His was doing it supposedly in all functions. Mine only in certain ones; most particularly the +DC. It doesn't like that one at all!
Anyway, supposedly the schematic verifies the positive ground on the D cells. I was wondering why there was no indication of polarity anywhere. Heck, you would think that they would be even more inclined to indicate polarity in a reverse polarity application. I don't have the meter here with me, but I will give this a try as soon as I can and update the results. Hopefully they will be good results!
OK, today I went in and replaced the two electrolytic condensers along with a .1 and a .05 wax/paper/foil condenser. All of them measured way off with the capacitance function of a Fluke DVOM, so I figured I would definitely see some improvement, or maybe even have a working meter. No such luck!
![]() Absolutely nothing changed! Before I go much further I must add that I do have a questionable 6SJ7 according to my tube tester. It is a cathode follower for what that is worth. Maybe the weak tube is the whole problem. I don't yet know exactly what function it performs. No subs to try in my metal/glass goldmine.
