Old 01-18-2015, 04:21 PM
crh4881's Avatar
crh4881 crh4881 is offline
1985 RCA colortrak 2000
Found an 85 colortrak 2000 off of craigslist its in really good shape, has a very strong picture and the sound is really good, it also came with its big remote command center. I will probably use it as my daily viewer since its working so well, plus it has a lot of input/outputs.
Old 01-18-2015, 04:30 PM
rca2000's Avatar
rca2000 rca2000 is offline
I have two of these...both DID work to some degree. I think the tubes are ok in both. However--I think the cabinet on at least one got messed up some--from the old garage. Both were " shopping finds" and free. CTC 131 chassis. STILL want a "dimensia" version though.
Somewhere--I have at least one of those big remotes I think NIB.
Old 01-18-2015, 04:31 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
That's a nice set. I would connect external speakers to one; I assume that side-firing speakers aren't very nice to listen to.
dishdude's Avatar
dishdude dishdude is offline
Wow nice find! That set looks like it's brand new.
Old 01-18-2015, 05:40 PM
We saw quite a few of these. Excellent sets with just
a few common problems. I remember a few yrs earlier
when the cube style came out we used to beat up on
the Zenith salesman for not having a comparable set.
You could get a Zenith just as good but not with the
kick-ass styling or jack pack RCA offered. Of course
Barney defended Zenith but also promised to drop a
suggestion at the next big sales meet in Chicago. They
even sang the Zenith song, wish I had that on a 45 !
A nice find right up with any 80's or 90's set. Only RCA
I liked better was the CTC167, an underrated set..........
Old 01-18-2015, 06:10 PM
That's one of the last real RCA's before GE took over.
Old 01-19-2015, 07:15 AM
Marco-nix's Avatar
Marco-nix Marco-nix is offline
Nice find crh... My Toshiba has lots of inputs/outputs like yours , mine has a flat CRT and love it .. recently I found a RCA entertainment serie 27' and had a poorly welded component and it did not work but I re-did the weld and it works fine now ... It was a small piece of metal near the flyback..
Old 01-19-2015, 11:13 AM
VintageLove's Avatar
VintageLove VintageLove is offline
Vintage Junkie
Nice set you got there crh4881! I have the '82 model. Interesting seems '85 was the year RCA redesigned the front control layout and rear connections. Maxm has the '84 model and is identical to mine. I really like that glass bezel and the option to hook up external speakers. I'm curious if RCA was still using the LDR on these that radiotvnut had mentioned.
Old 01-19-2015, 11:40 AM
RCA used the LDR on some of their sets until the early '90's. I had a 27" Colortrak 2000 from around '90-'91 that had it. I don't remember the exact chassis; but, it was something in the CTC157-67 series. It was not a CTC140 or a 169.
Old 01-19-2015, 12:11 PM
dishdude's Avatar
What's LDR?
Old 01-19-2015, 02:20 PM
crh4881's Avatar
It has a switch called DNR im not shure what that means.
Old 01-19-2015, 08:10 PM
Originally Posted by dishdude View Post
What's LDR?
LDR is an abbreviation for Light Dependent Resistor. These were used in TVs of the '60s-'70s (Magnavox comes to mind, though other sets may have used them as well) to automatically adjust the brightness of the picture under various room lighting conditions. This feature was generally found in high-end Magnavox color sets, such as their fabulous 25" three-way entertainment center (TV, phono, AM-FM radio) of the mid-'60s, and a few standalone console TVs of the same vintage. It could be defeated by a switch if the user wanted to set brightness and/or contrast manually.
Old 01-19-2015, 09:13 PM
dishdude's Avatar
Thanks My first Zenith had this...it was a menu option I could turn on and off called Light Sentry.
Old 01-27-2015, 02:49 AM
Telecolor 3007's Avatar
I love old stuff
The L.D.R. techonolgy is so old? I thought it was from the '90's.
Anyway, since I've seen the title I knew it was about an really wooooooooooow tv set!
Sailor Moon
Old 01-19-2015, 02:28 PM
Dreamsbeard's Avatar
Dreamsbeard Dreamsbeard is offline
DNR stands for : digital noise reduction.
