Old 02-17-2015, 09:28 AM
66 motorola contrast issue
i have a 1966 motorola 23 inch and if i turn the contrast to make the picture sharp the screen pulls in on one side. this set was recapped and works great its just the contrast if i want to make it sharper and as i turn it in that direction the screen pulls in. any ideas ......
Old 02-17-2015, 10:21 AM
Color or B&W ? chassis ## ( ts### )
a screen shot also if possable
AGC ( aka optimizer) too high
Weak hoz out or other sweep tube.
Try adjusting hoz hold.
HV regulator, color only.
Old 02-17-2015, 10:22 AM
I sounds like a HV regulator problem. What chassis number is it? A TS914?
Did you check the 3AT2? It might be blooming! It's been ages, since I worked on one of them. Also, the 6LY8 was overworked in that chassis. Try replacing it.
Old 02-17-2015, 10:52 AM
it is a color set and there is no 6Ly8 maybe a different one ? the chassis is a 908 and i have the schematic that covers both aets908ye and the ets908ye. this is the set that uses 2 hots. it does seem to bloom when the contrast is turn to make it sharper.
Old 02-17-2015, 05:09 PM
I would start with a check of the HV regulation, see if it vary's as the sides pull in.
Old 02-18-2015, 01:14 PM
The ETS908 chassis was really an overbuilt chassis. That was my first color set, bought brand new.
One day, it started blooming and going out of focus. Both the 3AT2 and the 6BK4 were weak. That was when the set was around 7 years old.
We only ran it for 10 years, until the original 23EGP22 got too weak to produce a decent picture. The video output tube in that chassis is a 6HB6.
Old 02-18-2015, 02:11 PM
yes this chassis does look over built and it does look like the hv is not regulating and this is the cause but for now it has a great picture even when certain scenes show the hv dips to 19kv but is still bright and clear and dont bloom. maybe because the crt is in great shape as it was replaced in december 1980. i did try another rectifier tube and hv reg tube no change . so one day maybe ill tackle it but for now it only goes on maybe 3 times a year.
Old 02-18-2015, 02:27 PM
if a new HV rec and HV reg do not fix, then I would look into the horz out, could be weak. Is this the set with two horz outs?
Old 02-18-2015, 02:53 PM
yes its the one with 2 horiz outs.
Old 02-18-2015, 02:29 PM
DavGoodlin's Avatar
Motorola Minion
Timmy ,
Please post a picture of this set. I had a metal cabinet TS914 once but this is a bit older. Mine had the color indicator light and the "tint" control. It had a good 23EGP22, rare as they are.
-Dave G
Old 02-18-2015, 03:13 PM
Originally Posted by DavGoodlin View Post
Timmy ,
ok heres the overbuilt beast, with the really good 23egp22 this one has the color light as well. this one is the 908 chassis.
Old 02-18-2015, 05:55 PM
-WOW- That is a nice tv ! !
I think the problem is that Timmy sucks HV right out of whatever tv he is next to-
A good 23EGP22............... Timmy has a time machine too..........?
That is a really nice cabinet...... Real wood....?
Old 02-18-2015, 07:29 PM
DavGoodlin's Avatar
Motorola Minion
Yes, exactly what squirrel said! Nice one- really!
-Dave G
Old 02-18-2015, 07:52 PM
Yeah, from what I've red here I'd estimate the number of good 23EGP22s known to exist at around 10.
Old 02-19-2015, 08:43 AM
Make that nine. I regret to say, I bought one last fall, that went to air before I received it.
