1941 Zenith 8A02/8S563 Console found
I got this at the flea mall today for the princely sum of 75 big ones. I have no idea if it works, the cord is almost non existent. But I wouldn't have tried it anyway. I will be taking it to my local antique radio club this weekend and see what's going on with this thing. They may or may not remember me. The last time I was there was when I got my 1941 Philco 42-327 in September. I have never worked on a Zenith before, any tips or advice is very much appreciated.
Quality vintage television service by Alabama's original Animegao Kigurumi performer. Last edited by TUD1; 08-07-2016 at 10:21 PM. |
Here's the back. For some reason, my i-Phone will only allow one picture per post.
The 6X5 tubes are prone to shorting and taking out the power transformer. Replace them with 1N4007 diodes.
Rotted rubber insulation on wires in this era of Zenith can be tedious to deal with.
And put a 1/8A. fast blow fuse in line with the power tranny HV secondary center tap. Perhaps a 1A. Slow blow fuse on the primary.
I got this radio just in time for BirmingHAMfest 2015. They always have all sorts of tubes and testing equipment. I'll be sure to get the tube names for this radio and check for them at Hamfest.
Quality vintage television service by Alabama's original Animegao Kigurumi performer. |
Just get 2 1N7007 diodes from your local Radio Shack or dealer of choice, remove the cathode and plate leads from the rectifier tube socket (leave the heater attached so it glows and looks original), add a terminal strip nearby under chassis, and attach those leads and the diodes (observing proper polarity).
I have been informed that 8A02 is the chassis no. and 8S563 is the cabinet no.
I'm expeienced in toilets, lights, and vacuum cleaners. But I'm not very experienced in tube radios. I'll have to study the rectifier tube socket and all sorts of stuff before I can do that. Can you explain that just a little bit, please?
Can anyone tell me about small low power AM transmitters? The local AM station that I very much enjoyed is defunct, so now I have nothing to listen to except gospel and jabber-jabber. I hate both. Any ideas how I can play my own music over my antique radios without making the FCC mad?
Label and disconnect the leads on the socket pins K and P in the above diagram. K is the cathode. P are the Anodes (called plates in tube speak). A 6X5 is 2 diodes in the same bulb with the cathodes connected together. Above is the symbol for a 1n4007 diode the stripe on the part's body indicates the cathode end. It should not be too hard to figure out the connections from here. It took me less than 3 minutes on google to find the pictures to make this simple to explain. I happen to like talk radio when they have something interesting to discuss, but music is also important to enjoyment of such equipment.
They make a lot of styles, a friend of mine that had an AM-100 transmitter just bought one of these off ebay, says that it's a TON better than the one he had
http://www.ebay.com/itm/Talking-Hous...item5670c4da30
"Restoring a tube TV is like going to war. A color one is like a land war in Asia." |
TUD, I have that same Zenith and i got it off CL for $60 knowing the transformer was toast due to the 7Y4 tube,just as bad as a 6X5, of course.
It does not list that model number, just that chassis number - Very strange Mine also has a 6K7 in place of the 1232 as an RF amp I have a spare chassis (with a good trans) and speaker from a 8S359, also similar but with the evil 6X5. Just haven't put the two together yet...
"When resistors increase in value, they're worthless" -Dave G Last edited by DavGoodlin; 02-21-2015 at 09:12 PM. Reason: rf amp note |
My Zenith does not make use of a 7Y4. Here is the schematic.
Do you all feel the same way about ALL of the indirectly heated rectifier tubes--like 6AX5, 6CA4, 6X4 , 5AZ4 ?
Some of the LAST 6X5s supposedly were 6X4s or 6CA4s in an octal envelope, and were as safe as the rest of the later types, but if someone like me who has been doing this for over a decade has a hard time telling the difference, then advising a novice to do so would be a bad move... I don't want to give him advice that could lead to an expensive component (the power transformer) being ruined.
Tom C. Zenith: The quality stays in EVEN after the name falls off! What I want. --> http://www.videokarma.org/showpost.p...62&postcount=4 Last edited by Electronic M; 02-19-2015 at 04:42 PM. |
