Old 02-20-2015, 08:55 PM
Robb's Avatar
Robb Robb is offline
Question Is this a Portacolor ?
flickr
Old 02-20-2015, 09:02 PM
No....
Portacolor sets had 10" screens...
Looks like an early solid state set.... possibly tube hybrid, but most likely early ss.
Old 02-20-2015, 09:17 PM
rca2000's Avatar
rca2000 rca2000 is offline
Perhaps that tube chassis form about 1971 or so with the lead-covered HV rect. tube. C-something chassis.
The one that burned up the PS board a lot, from what I hear.
Old 02-21-2015, 10:49 AM
No....
Ge never changed their cabinets much. Look at their radios. That one clock radio, must've been made for over 10 years, in both tube and solid state.
Their radios weren't that highly styled to begin with, not like some of the other makes.
Ge made a 15" set around the same time as the Porta-color. I saw one in the schematic book, but never ran across one. I heard, they were real dogs.
Old 02-21-2015, 06:40 PM
That was a rare set. IIRC it was 16". Had a Rube Goldburg channel
indicator w/ lots of CHEAP plastic gears. We were told NOT to try
fixing them, let them count from a known channel. Didnt matter
they only got the local Boston stations anyhows. A real piece of
crap. Made the portacolor look like a high end set........
Old 02-20-2015, 09:20 PM
You think that tv is that old....?
Old 02-20-2015, 09:34 PM
rca2000's Avatar
At least a JA or QA chassis set I would say--if not the tube set. 1975 or OLDER.
Old 02-20-2015, 10:24 PM
Pretty sure its a C-2 chassis 18/19" all compactron & lead
HV rect. Were common as hell under GE, Bradford ( W.T. Grants)
Packard Bell & others. Very low priced for a reason. Must be
rare now as so many were junked at an early age. I think
it would be a fun project. Some had a very good pix, never
could understand why
Dont think it the JA or QA SS chassis. If it were it would be a nice catch.
Old 02-20-2015, 10:25 PM
Probably has a 15-19" screen by the looks of it. If it is tube you should save it....Both on principal as a collector, and because non-portacolor color GE sets are rather rare. Some one may trade you a portacolor for that if it is a desirable enough chassis.
Old 02-20-2015, 10:48 PM
rca2000's Avatar
I think I have a QA chassis set--if it didn't get stolen, with a "truetone" label or something like that.
Old 02-20-2015, 10:46 PM
BigDavesTV's Avatar
BigDavesTV
I remember working on one of those GE Color sets, years ago! IIRC, the set I repaired had a shorted LV Rectifier Diode. I'm quite sure that set has more than a few tubes inside. I saw many more Porta Color 10" sets, rather than those larger screen table top color GE sets. Worth saving, looks like nice cosmetic condition too.
Old 02-20-2015, 10:47 PM
If I found that set cheap I'd have to get it just to keep it out of the Recycle bin.
Old 02-20-2015, 11:23 PM
That's a "lug-a-color" set and probably the tube/transistor hybrid chassis (I think they continued to use a version of that chassis in low end models until '75 or '76).
I have a two 18" C-2 versions of this set from '72 or so. One is branded Packard-Bell and had a nearly dead CRT. After rejuvenating it and playing with it, I got a fair picture out of it; but, it still needs work for it to be reliable.
A few months ago, someone at the flea market gave me the GE-branded version; but, it's past going. It's been out in the weather for a long time and was full of mud when I got it. The plus side is that the CRT test very strong; so, that tube will probably end up in the other set.
During the past 25 years, I can count on one hand the number of 19" GE tube color TV's that I've found (probably because they didn't hold up well and most of them probably were junked by the early '80's). I recall having one cheap GE 23" color console that had basically the same chassis as the 19" sets and I had one nicer GE color console that used the KD chassis.
I've seen my share of tube porta-colors, 12"/15" tube B&W's, and solid state GE's from the late '70's and '80's; but, not much else by GE. Wait, I remember having an old GE hospital set. I don't remember the chassis; but, it was SS and I think it used a delta gun CRT. It was very beat up and I gave it to a friend for parts.
Old 02-20-2015, 11:35 PM
Being outside for even a few years is not necessarily the end of a set unless you let it be. I've gotten some hopeless looking outdoor sets to run. All outdoors means is more work to fix it. There are early radio equipment restorers who have taken marconi era sets that have been underwater (on sunken ships) for most of their lives and look like they are encased in concrete from all the effects of being underwater, and made those things back into working radios (somehow). If it is all there and nothing is smashed, then it should be repairable.
Old 02-20-2015, 11:27 PM
Here's the 1975 version:
https://www.youtube.com/watch?v=0Pl1ReVL_2k
