Old 08-27-2015, 07:42 AM
1980 Zenith System 3 portable with electronic tuning
I got this TV from Wayne this weekend when I helped him install a new CRT and reassemble the components in his 1964 Zenith "Chancellor" roundie combo. Wayne is a great guy, I enjoyed discussing his memories of working in engineering for both Motorola and Zenith back in the 60's and 70's (respectively).
Wayne bought this set brand new from Zenith Employee Sales, which was then part of the Dickens Ave. plant. Wayne being the original owner and giving me the set makes it special and he took great care of it over the years.
This one features "Omni Electronic Tuning" which is a continuous graduated drum type VHF/UHF tuner. I've seen this model maybe once or twice in the past, but never owned one. I kind of forgot they existed. I don't think it was a very popular variety among the 1980 portables. The tuning knob has a flyweight on it, so it turns smoothly and doesn't feel "cheap". VHF/UHF is selected by a rocker switch below the tuning indicator. Incidentally, that rocker switch is the exact same type commonly seen on the earlier 4 tube hybrids!
The set doesn't have many hours on it. We were under the impression it would still work fine even though it's been years since it was last powered up. Unfortunately it appears some of the lytics may have showed their age and upon power up, the set gets only very low/weak volume, no picture and no dial light (which should light up green). Its as though it's not getting full voltage from the power supply. I'll be honest, I never worked much on System 3's, unlike the CCII's and earlier. Is there a common fault on these relating to these symptoms? Presumably some caps in the power supply? Cracked solder joints on the 9-160? I've yet to pull the back off.
IMG_20150825_212927363 by drh4683, on Flickr
IMG_20150825_213018917 by drh4683, on Flickr
Old 08-27-2015, 08:10 AM
sampson159's Avatar
sampson159
those little sets were dynamite!had a few through the years and they always delivered a stellar picture with flawless performance.my son had one in his room for 12 years until it was replaced with a larger set.
Old 08-27-2015, 08:16 AM
Always a good idea to pull the 9-160 & resolder it.
Also do the 9-155-01 CRT board. The main cap does go
bad but it causes width then hum bars. If the
9-160 is bad ( 98%) beyond simple checks I would just
replace it. Gotta remember that design is in the top 3
for complexity along with RCA SCR & Sonys with 2 SG613's
which its the worse. In the end there are only 2 different
ones, 9-160-05 & 9-160-06. They replace all other numbers.
Didnt sell many of them. IIRC they were just a little more
than regular tuners. Maybe they were trying something to get
away with a cheap alternative to tuners but didnt get
a good response. Selectors were reliable. I only remember
changing one for a dial cord.
Old 08-27-2015, 08:22 AM
BTW IIRC some of the 9-160's used a start transformers
& others used a multivibrator like 9-181 sets. If you upgrade
to an 05 or 06 one connector is left off. Thats from my
foggy memory
Old 08-27-2015, 07:52 PM
It's been ages, but I remember that the 9-160-6 was for the 25" models, where the 9-160-9 and a few others were for the smaller screen sets. They must've changed the designation later on.
The only electronically tuned set, I have of that series is an 18 position selector type.
They must've built that set, with the same basic cabinet styling for about eight years.
Old 08-27-2015, 10:45 AM
Resolder the crap out of the 9-160 module. I even recall getting some "rebuilt" boards that had crappy soldering that caused problems right out of the box.
Old 08-27-2015, 01:06 PM
Ok, I figured solder connections were a major culprit here. I'll investigate it this weekend when I get some extra time. Hopefully its a quick simple fix. I'd hate to swap out an original 9-160 if I don't have to.
Old 08-27-2015, 01:54 PM
Findm-Keepm's Avatar
Followin' the Rules...
CRSP entries for the 9-160:
Brian
USN RET 22YRS (Avionics/Cal)
Old 08-27-2015, 02:47 PM
Thanks Brian. It looks like this set will use either the 9-160-03 or 9-160-05.
Old 08-27-2015, 05:56 PM
I remember seeing those new also.... People didn't like the tuning much. The
Zenith guy said they didn't sell many....
Old 08-27-2015, 06:41 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Cool set, more interesting than its ordinary knob job equivalent.
Old 08-27-2015, 09:35 PM
Yes, Zenith often used the same cabinet design for years and with many different chassis variations.
