Old 11-29-2015, 04:37 PM
Radiotronman's Avatar
Radiotronman Radiotronman is offline
GE 810 restoration
I think I'll begin restoring my GE 810 10" tv. I like the looks of this set and I like how Bandersens turned out. Here we go....
Old 11-29-2015, 06:07 PM
Well the picture tube didn't test well and cooking it for 45 minutes didn't help much. Hopefully it will be viewable. Good news is that it looks like the flyback has been replaced. I've heard the originals are highly failure prone.
Old 11-29-2015, 06:09 PM
Flyback replacement is s GE 77J1
Old 11-29-2015, 06:16 PM
What makes you think it's been replaced? I'm pretty sure GE 77J1 is the OEM number.
Old 11-29-2015, 09:59 PM
ZackN920's Avatar
ZackN920 ZackN920 is offline
That sucks. That got a 10BP4?
I wonder if that set is related to my 806, electronically? Same era set. I wonder if it uses the same flyback as mine....I think mine's original, but after warming up, mine really likes to sizzle I'll probably have to replace it, but that set won't ever really be a watcher for me so....
Old 11-29-2015, 10:12 PM
I brought it up slowly on a variac and the speaker buzzed really loud. I did get a dim raster and and a few thousand volts on the second anode. I've got a b-k CRT tester, which I've tested crts on them before that tested bad, but we're viewable.
Old 11-30-2015, 12:54 AM
Loud hum from the speaker is a classic sign of bad electrolytic filter capacitors in the power supply. I wouldn't run it for any length of time without replacing those.
Phil Nelson
Phil's Old Radios
Old 12-04-2015, 08:05 AM
GaryK's Avatar
GaryK GaryK is offline
W9TOF
Location: Eastern Rural Walworth County Wisconsin near the southern Kettle Moraine Forest
GE 800 parts
There is an eBay seller posting in Vintage Television to sell his GE console for $50. It has a fried power transformer. Maybe it has useable parts.
http://www.ebay.com/itm/Vintage-Tele...8AAOSwu-BWO3u7
Old 12-04-2015, 11:33 AM
That's an early 1947 GE 801 and I think uses a different flyback. Also a very collectable TV in it's own right and I hope someone can restore it.
Old 11-29-2015, 06:35 PM
The one pictured in the sams looks totally different.
Old 11-29-2015, 06:41 PM
The SAMs list GE part rto-054 as the original.
Old 11-29-2015, 07:38 PM
Well for what it's worth, 77J1 and RTO-054 both cross to a Thordarson Fly 3. However, I think the 77J1 is original to your set. I have that exact same flyback in an 830 chassis.
Old 11-29-2015, 09:58 PM
I think it's original too as it looks the same as the one in my 810.
Old 11-29-2015, 11:45 PM
I think they came with a 10FP4 originally. 806 is a series strung set and very different design. Flyback might be compatible though.
Old 11-30-2015, 09:07 AM
dtvmcdonald's Avatar
Is a 10FP4 a direct replacement for a 10BP4, except it is aluminized? The RCA manual
implies that it is.
