Old 12-24-2015, 08:32 AM
iong iong is offline
Zenith tv channel indicator
What's the correct bulb to correctly display the projected number on the knob face. I once heard it needs magnified tip.I have a '64 Zenith 26mc20
Thank you,
Perry
Old 12-24-2015, 03:22 PM
Gunslinger Gunslinger is offline
what is the voltage?
Old 12-24-2015, 03:34 PM
Zenith projected channel knob indicator lamp
6.3v
Old 12-24-2015, 04:13 PM
I think they are standard bulbs....There is a separate metal light directing metal shield that goes over them that you need to have...
Old 12-24-2015, 06:10 PM
You can use a #47 or #44, but the projected image will be smeared/blurry.
The required bulb has the filament configured to provide a point source of light.
It has a designation number consisting of four digits, something like 1829 (that's not the number, but something similar) and danged if I can remember it. Somebody on here surely remembers it.
Old 12-26-2015, 08:00 AM
Yes- the correct miniature lamp you need is a #239. This is the right bulb for ALL Zenith channel window applications. Buying NOS from ebay is about your only source to find them now.
Old 12-26-2015, 09:16 AM
Yes- the correct miniature lamp you need is a #39. This is the right bulb for ALL Zenith channel window applications. Buying NOS from ebay is about your only source to find them now.
The numbers, I remember are #239 and #240.
The 1956 model B/W sets, used a PR12 flashlite bulb.
Old 12-26-2015, 09:23 AM
Dieseljeep is exactly right. I meant to say "239" instead of "39" and corrected it. Either 239 or 240 are the correct bulbs!
Old 12-26-2015, 01:25 PM
Steve D.'s Avatar
Steve D. Steve D. is offline
A google search shows several sources. Here's one: http://www.bulbtown.com/239_MINIATUR...BASE_p/239.htm
-Steve D.
Old 12-26-2015, 01:56 PM
drh is right. Get NOS from ebay. Got a few #239's from bulbtown and although the filament is angled. It displays the channel number same as #47 bulb
Old 12-27-2015, 07:22 AM
I will check today and see if I have some left.
Old 12-27-2015, 09:16 AM
I do not have 239 lamps. I have 51,53, 130, 1847, 159,259,the Zenith neon with long black wire leads. I seem to remember Zenith used the 130 lamps on a lot of sets.
Old 01-02-2016, 05:04 PM
Got my NOS Sylvania #239 bulbs from ebay today and they light the channel number brighter and sharper in my Zenith then the China ones from Bulbtown,
