Old 05-03-2016, 09:45 PM
Radiotronman's Avatar
Radiotronman Radiotronman is offline
Philco Briefcase 19
I gott a couple of these 19" Philco briefcase tvs and decided to restore this cool aqua colored one. The CRT tests great, now to conquer the predicta-like chassis in this set. Ive ordered replacement caps and I'm waiting for them to come in. I find working on these pcbs to be a fun change, but definitely gotta be cafeful with the heat when soldering. The insides were filthy and I cleaned the crt, a 19AMP4. You pretty much have to take the face off, with crt attached, to access half of the chassis. Should be a fun restoration.
Old 05-03-2016, 09:48 PM
Here is the chassis with CRT and face off.
Old 05-03-2016, 09:50 PM
Picture with just the back off.
Old 05-04-2016, 06:44 PM
decojoe67's Avatar
I have a restored Seventeener III that plays flawlessly. It reminds me of the 1960 Admiral I watched as a kid that was equally as good. Fun sets.
Good luck with the resto.
Old 05-04-2016, 11:07 PM
Sorry the picture isn't very clear. But on these top hat diodes , which side is the "in" or "out". I want to replace them with modern diodes, which has the cathode line at one in. I can never remember which way they go and don't want to waste my fusistor finding out...
Old 05-05-2016, 10:17 AM
The Briefcase 19 was a better performer, than the Seventeener III. The S III always seemed to have tuner problems, but the CRT's always seemed to be good.
The Admirals, that were similarly styled, stood up better, but the CRT's didn't last as long. IIRC, National Video sourced.
Old 05-05-2016, 12:10 AM
IIRC the brim of the hat is the same thing as the band on a modern diode.
If one is good the diode/ohms mode of your DMM will tell you.
Old 05-05-2016, 12:24 PM
reichsrundfu reichsrundfu is offline
Sweet. Built in multimeter and everything ...!! Sorry just couldn't resist
George
Old 05-06-2016, 11:38 AM
Well I replaced the electrolytics and get a brief raster before a 10uf 450v electrolyric gets hot and kills the raster. I'm going to find the schematic and see what's going on here. This section if a 4 section electrolyric goes to the height control.
Old 05-07-2016, 07:21 PM
That cap is in the boost circuit. The boost, generally furnished the plate voltage for the vertical oscillator circuit. More stable!
Old 05-09-2016, 08:54 PM
Well that cap keeps getting way too hot and the 33k resistor with it keeps getting hot and opening. While it lasts, the picture looks good, the width bounces from the right and shrinks back and forth.. Any ideas why?
Old 05-09-2016, 10:10 PM
About the only things that makes an electrolytic get hot are leakage current, installed backwards, or AC across it. You checked the damper tube?
Old 05-11-2016, 05:46 PM
Sams set 531 folder 2. All the best, Tom
Old 05-11-2016, 09:06 PM
The chassis is 11J27. I appreciate any help!
Old 05-11-2016, 10:40 PM
I suppose if the yoke is shorting you could be getting some high voltage spikes across it. I wonder what would happen if you pulled the vertical output, or the yoke plug, just to see if that keeps things cooler? Someone with more experience than I will know if that's a safe test to unplug the yoke.
