Old 10-08-2016, 06:49 PM
TinCanAlley's Avatar
Talking Finally, a complete one
So, I have gotten my hands on several of these old in-wall radio antenna sockets, but this is the first one that has the original plug. I've cleaned it up, but it still has some old paint in areas that are quite hard to reach. I think I'll leave it as is so as not to damage it. From a reasonable distance, it looks pretty new.
What I need to know is what kind of wire is needed for the plug. Is it just your standard cloth covered wire? The hole in the plug is kind of oval instead of round, but maybe this is so the wire fits snugly?
Also, I found no markings to help determine age. It was removed from an apartment in a building that was built somewhere between 1938 and '41. The socket was connected to blue wire (not cloth, but pretty old) and went up to the attic of the building. There was a long copper wire that has long sagged and fallen.
File Type: jpg In-Wall Antenna Socket and Plug (1).jpg (29.0 KB, 55 views)
File Type: jpg In-Wall Antenna Socket and Plug (2).jpg (32.3 KB, 55 views)
Old 10-08-2016, 09:13 PM
That ones a little different than the common Arrow-Hart type.
The original wire used was probably cloth covered rubber single conductor stranded wire. One for antenna, one for ground.
When I would see console radios at the Goodwill, many times, they still had that type of plug connected to the antenna and ground wires.
It was great, when the radio had to be moved for cleaning or decorating, but it always seemed the the radio always to be in the same location.
Old 10-09-2016, 11:58 PM
I think they might have been custom. The outlets in the building are Leviton, but the covers have a design around the edge that I can't find anywhere. I've searched high and low, but never found another to replace broken ones.
The wire used in the wall is 14ga. I guess they just used standard electric wire. As for the wire for this plug, I'm guessing it was around 16 - 18ga?
Old 10-10-2016, 10:36 AM
The receptacle pictured isn't a Leviton. The plates possibly are.
Even when that home was built, the wiring, rough and finish was done per bid. That home, possibly had a up-grade wiring job.
I'll look, the next time I go to the HFH Restore. Many times, they have the kind of plates you're looking for, but someone seems to be buying them up, probably to E-bay them.
Old 10-10-2016, 12:44 PM
Yes, you are correct. The switches are Leviton, the outlet is Mohican. The wall switches are ceramic with some having the ability to disassemble. This comes in handy to rebuild them if possible.
These are actually in two (close to twin designed) apartment buildings. For all the outlets they ran a black and a white. For the aerials, they ran blue and red. For the age, the wiring is in amazing shape. It isn't brittle at all and you can feel the rubber texture of the coating.
Old 10-10-2016, 08:06 PM
Mohican Relyon was the lower priced line of Arrow Hart&Hegeman.
Is the building wired in BX cable or knob & tube. Some areas used old style Romex without a ground, which had a woven cloth cover.
Old 10-08-2016, 10:16 PM
There were other types too...I saw one that was a normal single power outlet with 2 20's style speaker terminals for the ant and gnd connection...It was in the original house feeding the original late 20's RCA radio-phono that the outlet had been installed for.
Old 10-10-2016, 12:01 AM
I've seen several types. At first most thought these were single power outlets and must have been taken out of the circuit years ago. I started looking into them and found that once the paint was removed, it said "aerial" on it. Then I put on a protective suit to climb into the attic and crawl through all the blown in fiberglass insulation to located the termination point. That's when I found the long copper wired running about 130' down the length of the attic.
