Old 10-09-2016, 01:30 AM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Unusual 4-leg safety cap
This is in my 1976 Electrohome. Is anyone familiar with this kind? If so, are they failure-prone like the white Zenith and Magnavox caps?
I've put in a lot of hours on this set and have it working fairly well, I can't have it blow up now.
Grr, flipped photo again.
Old 10-09-2016, 08:04 AM
Dont think I ever seen one. Looks like it came
from Europe.
Old 10-10-2016, 10:46 AM
from Europe.
The ERO German caps were usually good quality.
I wonder, if Zenith named American Radionic, vendor of the year at one time.
The Magnavox replacements, were still made by them.
BTW, I took the hammer to the first one I changed. It was an oil cap and had a rubber band holding something together.
Maybe it was the rubber band that caused them to fail.
Old 10-10-2016, 01:38 PM
N2IXK's Avatar
N2IXK N2IXK is offline
Technohippie
The ERO electrolytics used in the Quasar "works in a drawer" sets were a common failure point...
Old 10-10-2016, 09:08 PM
Electrolytic caps were always a weak point, no matter what firm made them.
Old 10-11-2016, 01:27 AM
The old Zeniths used those orange four legged safety caps in their sets.I remember at my friends shop that we replaced them alot.
Old 10-10-2016, 12:33 PM
Jon A.'s Avatar
Yeah, I researched ERO caps last night. ERO is now Vishay. I found a post by Brian on ARF saying GE used blue ERO caps to replace the originals. Geez, did I use enough acronyms there?
American Radionics probably got a similar branding. Makes me think of the Dodge Omni/Plymouth Horizon being named 1982's "Lemon of the year".
By the way, what are the voltage and capacitance ratings of Zenith's 800-860 cap kit? I can't find this info anywhere. I have two of these kits and had one out for a look. The cap itself is marked 22-7504-01.
Old 10-14-2016, 01:40 AM
Jon A.'s Avatar
So, the only thing I can safely replace this with is several orange drops connected parallel, adding up to the original's value? I reckon I can't get a suitable 4-lead orange drop.
Old 10-14-2016, 05:32 AM
Findm-Keepm's Avatar
Followin' the Rules...
So yours is bad? It's of the same generation as the Blue EROs, which are the good kind.... that "-4d" is the key. Blue ones are also of the same generation of KP1831 caps:
http://www.ebay.com/itm/1pc-0056MFD-...-/182302985736
What's wrong with another ERO? Saw them for years, no problems. The blue ERO/Roerderstein caps are constructed like the orange drops - they have a failsafe construction - opening up the B+ line to the collector of the HO Transistor. Do a google search by value - somebody probably has one stashed somewhere. I'll look at some of my GE stash - I know I have the two lead variety, but not sure of any 4-lead stuff.
Brian
USN RET 22YRS (Avionics/Cal)
Old 10-14-2016, 06:26 AM
0.011uF Sprague, 4-lead:
http://www.ebay.com/itm/SPRAGUE-PP16...YAAOxy6MBSQKOh
The "s11" is the value - a single zero, followed by two ones.
PP=polypropylene
16=1600V
S11=.011uf (S=Single, D=dual, P= none, D11 would be .0011uf, P11 would be .11uF)
S=Critical safety component
Brian
Old 10-14-2016, 09:05 AM
Turns out, I have 3 different GE Blue ERO caps, 7 in total, all NOS. They are the -4d (4=4-lead, d=generation, the last and best...) They are .0047uf, .0062uf and .0065uf, all pointing to large screen GE sets. One is out of the package, and measures within 60pf of the marked value, after all these years, albeit never under load....
Sorry, no .012uf.
The white and gray baddies:
Brian
Old 10-14-2016, 09:32 AM
Theres your answer Jon...... I didnt get msg til last nite.
The Zenith kit is 800-860 . Often on E-bay.
BE VERY CAREFUL TO CHECK THE VALUE !!
The 13" 13GC10 + & the 17" & 19" EFL jugged sets used a different value.
Orange ones did fail. Either shorted popping breaker or opened causing
no HV. Never had one fail with causing too much HV.
Remember the blue ones in Warwick sets but never had a fail.
They were used in that terrible 19" with an RCA bonded yoke set.
Early GE SS sets used a 2 lead white cap behind the HOT.
went left & right. Instant death for the HOT. Change any white ones,
good ones were blue & from Europe IIRC. The white ones would
come apart by pulling on the leads even if still "good".
Maggy same as Zenith. Change any white ones. Sets with
703744-## reg modules also had a shut down. Too much HV would
cause the hoz osc to go way off with narrow pix to prevent disaster.
The symptom is usually the reg board or PC cons.
Other sets with this type SD circuit were RCA, Panny, Hitachi
& probably others. Can be very confusing....
Old 10-14-2016, 09:49 AM
13" sets used the 800-863 (3 and 13 end in 3...easy to remember)
17-19" sets used the 800-860 kit, AFAIK. Correct me if I'm wrong...
I know of one other kit, the 800-896, but I think it's for flat chassis sets.
All you really need out of the kit is the cap and the sleeving - most caps can hold themselves in place without the zip tie, and the label for the back is most likely dried out by now.
Brian
Old 10-14-2016, 11:15 AM
http://www.ebay.com/itm/ZENITH-RADIO...8AAOSwjXRXcAIA
The focus divider is the kit for 4 tube hybrids.
Old 10-14-2016, 11:16 AM
...Never had one fail with causing too much HV.
I've seen it in Zeniths. It cuts the neck off right where the neck joins the bell of the jug. Perfectly clean cut, slick as a whistle.
