Old 11-07-2016, 12:07 AM
miniman82's Avatar
First Light: 1952-2011
CTC-2B Ballast
I have a spare 2B chassis, but it was missing the ballast. I was able to locate one, but the resistive elements inside have gone open circuit so now I have to make a decision.
Do I:
A. Try to find some resistive wire and make original style elements for the inside and 'restuff' it so to speak?
Or
B. Tack some high wattage sand resistors inside the low voltage cage, and leave the empty ballast tube for visual purposes only?
If I go route A it could be tough trying to cram enough wire inside, the original elements were very fine wire wrapped around a (asbestos? Fiberglass? Silica?) core, sheathed in more fire retardant material. Probably be really hard to duplicate anyway. If I go route B that obviously works for this chassis here, but the ballast is electrically pointless then and can't be swapped into another chassis for troubleshooting.
It may even be possible to cram sand resistors inside the old ballast can, but I don't know what wattage to use since none of the schematics I have tell me how much current the ballast has to deal with.
What do you guys think?
Evolution...
Old 11-07-2016, 08:59 AM
kvflyer kvflyer is offline
If the ballast is like the ones that I have seen, they are wrapped around a slice of mica; not hazardous. But... the wire is nichrome and you can't solder it, it has to be crimped. Maybe tne open is at the connection in the ballast?
Old 11-07-2016, 02:56 PM
miniman82's Avatar
I was hoping for that, would have made an easy repair. Both elements were open somewhere near the middle, meaning I have to start over from the beginning.
BTW, you're only an hour from me in Great Mills- stop by sometime.
So looks like the only viable option here is probably mounting some big sand resistors in the LV cage then? I hate doing that, but this chassis is already a little hacked I suppose. Had a 6JE6 in it for H-sweep when I got it. lol
Evolution...
Old 11-07-2016, 09:42 AM
That is easy to deal with. Assuming the ballast uses a standard (presumably octal) tube base/socket just get another base socket pair of that type, and if your other chassis has a good ballast make a socket extender/breakout adapter with the extra base/socket pair to allow you to insert a current meter in series with each resistor such that you don't have to disturb the original wiring.
Old 11-07-2016, 10:28 AM
IIRC, it's not used as anything but a surge limiter. It depends on where in the circuit it is used.
Never have worked on one, I only seen one close up at Nick's place.
Old 11-07-2016, 11:04 AM
I just remembered I have the Riders vol 13 coverage on CD rom. Thanks Jim Menning!
I appears to me, that it's a voltage divider for the IF strip and the field neutralizing circuit. I don't have a schematic for the CTC2B. This info is for the 15" set.
Two twenty watt resisters should fit inside the can.
Old 11-07-2016, 11:21 PM
WISCOJIM WISCOJIM is offline
You're welcome. BTW, feel free to make and share copies of those to anyone who wants them.
Old 11-08-2016, 08:13 AM
I think the ETF has the CTC2B/21CT55 service lit in their color technical info page (along with every other RCA roundy).
Old 11-08-2016, 09:29 AM
I had a touch of the flu yesterday and things didn't register as well. I never thought of looking there.
Old 11-08-2016, 10:43 AM
Yikes. Hope you get well soon.
Old 11-07-2016, 11:14 AM
StellarTV's Avatar
StellarTV StellarTV is offline
Some of the elements in Motorola ballasts have been successfully replaced with non-polarized electrolytic capacitors. 10uF works to replace the resistive line cord in 30s era radios. You can probably find a similar solution and save a resistor or two.
Old 11-07-2016, 11:44 AM
Calculating from the voltage drops involved (400 to 285 V) with some guesswork for amount of current drawn by the vertical centering circuit, it would appear that both the 500 ohm and 430 ohm resistors should be at least 26 watts rating.
The capacitor trick won't work here as this is strictly a DC circuit.
Old 11-07-2016, 02:22 PM
TV'S&MORE TV'S&MORE is offline
Service literature shows 315 ohms between pins 1 and 3 800 ohms between pins 1 and 2 My ballast measure's 310 and 830
Old 11-07-2016, 02:55 PM
Interesting... my RCA field service guide (1955-1966 color) shows that R-101 (between pin 1 &2) in the ballast is 800 ohms (I mis-read as 500 ohms) but R-102 (between pin 1 &3) is shown as 430 ohms. There is also a jumper shown between pin 5 &7.
Recalculating for 800 ohms I get about 17 Watts for R-101.
Old 11-08-2016, 03:01 PM
If the heater string adds up to around 84V, you can use a rectifier diode, without any filter cap, to effectively drop the 120VAC line. This saves the energy that would be wasted as heat. Remember, it's power = volts squared over resistance. The diode cuts the power in half, and the effective voltage is 120V times the square root of 2 (from the half) which then = 84V.
