Pilot tv
Does any members here know if there is retrace mod out there for the pilot tv like the one that is for the Motorola tabletop sets, the resistor and cap. Maybe something similar for the pilot ?
If you mean the TV-37, it has DC restoration, so that should
not be needed. I've never noticed any problems with mine. |
Well it's the one without the ballast whatever that is as far as model go. It has the typical retrace lines like the Motorola sets have and lowering the bright they get less just like the motorolas.
The TV-37 has the same combination sync and DC restoration circuit as early Muntz sets. Judge for yourself whether you think DC restoration and prominent retrace are mutually exclusive....
https://youtu.be/sB-2hxZZsv0?t=13s
tvontheporch.com |
The National TV-7 has the same circuit as the as the TV-37,watch Bob Andersens' video on his set on adding retrace blanking. All the best,Tom.J
Where is his video on the retrace blanking.
About 3.5 minutes into this video he discusses and demonstrates the mod:
https://m.youtube.com/watch?v=Hfx1wgzk-uI jr |
Ok great thanks I saw the video, and I hope I got it right , cut number 3 from crt and place a 150 k in between and pin 5 of the vert output a 220 mmf cap from there to pin 3 .
