Old 07-14-2018, 11:09 PM
mrflex65's Avatar
mrflex65 mrflex65 is offline
Help with a Sony TV model # ID?
Good evening folks!
It's been awhile since i posted here and hope everyone is doing well. I need your help in recognizing a 19" Sony TV. I responded to the ad only to get a response of " what difference does it make,it works!" Does anybody here think they can recognize it by just the picture alone and is it worth the $50?
https://raleigh.craigslist.org/ele/d...634156659.html
Also saw this Zenith for sale, but it's way out my price range and it's way to big for me to move around! Though id post it here for prosperity.
https://raleigh.craigslist.org/ele/d...637525669.html
Thanks guys!
"IPC 610 Class E & J STD-001 Certified"
Old 07-15-2018, 12:13 AM
That Sony is worth them paying you $10 to take it so they don't have to pay $30 to dispose of it. Only the early trinitron/chromatrons of the first few years and the sub 10" portables have value.
That Zenith is nice, but also seems a bit overpriced...Probably a $50-$150 set unless a decorator with more dollars than sense competes with you to buy it.
Old 07-15-2018, 12:27 AM
dishdude's Avatar
dishdude dishdude is offline
Both look nice and overpriced. Maybe $20 for the Sony and $50 for the Zenith...on a very good day.
Old 07-15-2018, 08:56 AM
Sony is apx 1980. Not a bad set to deal with. Value is $0 IMHO
I think its a 19" set. If model starts KV19## its a 19" KV21## its
a 21" etc. If you like it pay abt $20 max.
The Zenith is called a "Panorama". Its designed for a corner but
you can use it against a wall. They sold quite well, more than any
other ultra modern Zenith. Its either a late System 3 (9-160)
or an early Advanced System 3 (9-214). Usually still running
fine. May bring up to $100 if perfect.
If you get the Zenith bring gloves. The bottom will dig into your
hands & it will want to twist due to weight distribution. It does
have casters so roll it most the way.
Old 07-15-2018, 09:51 PM
Popester's Avatar
Popester Popester is offline
Hard to tell from the picture if it's a 19" or a 21" size. My guess about 1981 or 1982 model year. It's a remote and probably has lumisponder and econoquick for fast warm up of CRT with no holding voltage to cathodes while powered off.
My wish list:
Sony KV-7010U
Sony KV-1220U
Old 07-15-2018, 10:00 PM
mrflex65's Avatar
Thank guy's, i really appreciate the feed back!
In terms of performance, how does the Sony rate?
I would like to use an analog set for the master bedroom. I'm currently using a LG 32" LCD and it gave me quite a bit of a scare the other night when the power went out twice
and after the last one,the standby led woudn't come back on until i pulled the plug and put it back in! Do you think it's a sign of things to come or it just had a glitch and had to reset it self?
Old 07-15-2018, 10:15 PM
mrflex65's Avatar
How about this one?
https://raleigh.craigslist.org/ele/d...636251212.html
Old 07-16-2018, 07:41 AM
Originally Posted by mrflex65 View Post
Thats about the same age as the other Zenith. Its a 23".
Its an odd ball as it has the good tuners but seems not to have an
auto color button.
Probably not part of the regular line but a "drop in" that mostly
went to the big stores. The gold is not original.
Your LG probably had microprocessor lock-up. Caused by surges, static
or messing with the keys randomly. Quite common. All it takes is one
gate out of thousands to get in the wrong state. Best to plug all
the electronics into one QUALITY outlet strip. Then if you have
thunder storms or high winds dont trust it !!! UNPLUG the whole thing.
Due so when on vacation too.
Old 07-15-2018, 10:23 PM
Popester's Avatar
Sony trinitrons, with the exception of a few models that would blow a bunch of components when hor output transistor/scr would short out. KV-1920 and KV-17## models in 1977. By the early 1980's Sony had such a reliable tv with a sharp bright picture that were hard to beat in picture quality and reliability. The downside to Sony was the cathodes were quite delicate and couldn't be rejuvenated very well or at all. Picture tube had a shorter life span than set that had delta type gun structure and shadow mask. But in there heyday they were the set people wanted to buy. Yes, they were expensive. Anyway, all that to say this, if the picture quality is still pretty decent and tracks well on a black and white setting from low brightness to highlights I would say go for it. $50 is probably a stretch maybe $10- $25. That was a decent year. I think their overall quality started to slip away about 1985 or 1987.
My wish list:
Sony KV-7010U
Sony KV-1220U
