Old 07-16-2018, 09:23 PM
Sealtest Sealtest is offline
RCA mini B&W tv with a very dark screen
I picked up this little RCA from the local recycling center. It powers on and I can see snow, but the screen barley lights up. The brightness and contrast are maxed out and did slightly help, but the screen is still too dim to see anything.
What could be causing this? I wasn't sure if bad caps could cause this or what, but recapping this could be an option. I would just need to grab a few newer TVs and pull the high voltage caps out of it.
Old 07-16-2018, 11:31 PM
Popester's Avatar
Popester Popester is offline
Don't rule out the possibility of a bad jug. Could also be a cap or transistor in video drive circuitry.
My wish list:
Sony KV-7010U
Sony KV-1220U
Old 07-17-2018, 12:53 AM
Model number, or picture?
Is this one of the 8" sets from the 50's or a newer solid state set?
Older set has an Ion trap that could affect the brightness.
Old 07-17-2018, 09:39 AM
Most likely CRT. If you leave it on & it slowly gets brighter
99% its the CRT.
Old 07-23-2018, 02:39 PM
If the problem is the crt then this project is toast. It’s odd though, but out of all the tvs I’ve owned RCA is the only brand so far that’s come in with a bad crt.
I did notice that the plunger at the side of the CRT (I know it’s called something else but the name escapes me), is missing. A picture should be attached to show what I mean.
File Type: jpg F2B237EF-A6DA-4C18-97F6-1E5CF2532D13.jpg (57.3 KB, 27 views)
Old 07-23-2018, 04:14 PM
compucat's Avatar
compucat compucat is offline
1949 Motorola 9VT1
Not all sets have a suction cup at the second anode connection. Your set is not missing anything. that looks like a 12 inch black and white set. nearly any CRT from a similar set should work. if that set was in a kid's room or was someone's only TV it probably has high hours on it and just used up the CRT. I like those little 12" B&W sets and try to save them whenever I can. With a converter box, or a Roku and a modulator they are still very useful.
Old 07-23-2018, 05:57 PM
Looks normal. A lot of B&W sets dont have the big rubber boot like a
color set. Also on a B&W like this a "dark picture" is almost
unheard of except a bad CRT. Well they were a good set in its day
right up there with Zenith & Panasonic 12" sets. She is just worn out.
Old 07-23-2018, 08:27 PM
I have a nib 12cnp4 if that will work.
Old 07-23-2018, 09:34 PM
Well I guess for now this project can be set aside. I don't really have the money to justify buying another CRT but this tv will certainly not be thrown away or anything like that. I frequent the local dump just to save these old tvs for fun, which is where this set came from. Since this is a 12" set maybe another parts tv will come along, but it might be hard to find the proper tube for it.
Thank you all for the info. Hopefully the next project will have more life left in it.
