Old 04-14-2020, 12:23 PM
gdubbs gdubbs is offline
Magnavox Windsor Imperial - TV Help
Hello all, I'm new to the forum, and look forward to getting to know you.
Several years ago I found a Magnavox Imperial Windsor on craigslist for $500. Neither the seller nor I knew what it was. It was a family pass down for him, and my first old radio. I knew it was special by the looks of it.
It is very original, with some cabinet dings from moving the beast over the years. I recapped the radio and amp a couple years ago with success. :-)
Always wanted to get into the TV, but was intimidated. Recent retirement gave some time to recap the (paper and electrolytics) the TV. Getting the Ecaps into the chassis turned out to be a challenge. I ended up placing them schematically correct under the chassis, but fear that I have introduced some noise and unintended performance abnormalities. After reading through others solutions, I have decided to remove the old ecaps mount a board above the chassis.
I am able to power up the unit and light the CRT, but the vertical scanning is only half height ~5" at the full height adjustment. Additionally, it appears to be compressed at the bottom of the scanning. Are there other components I should be looking to replace? Tell me its just a tube
Thanks in advance!
Greg
Old 04-14-2020, 12:52 PM
Check resistors and tubes in the vertical stage as well as B+ voltages and Boost voltage if the flyback boost powers the vertical as is done in many sets.
Old 04-14-2020, 05:05 PM
Thanks!
Thanks Tom!
As a mechanical engineer, I have to admit that I'm still coming up to speed on schematics. Let me see what I can teach myself. Can you direct me to transformer outputs or potentially tube numbers? here is the schematic https://www.earlytelevision.org/pdf/...sams_62-13.pdf
Stay Healthy! Greg
Old 04-14-2020, 05:23 PM
V17 a&b?
Old 04-14-2020, 08:11 PM
Originally Posted by gdubbs View Post
V17 a&b?
Yes those tube sections and the resistors around them.
Old 04-15-2020, 09:06 AM
thank you Tom!
Old 04-14-2020, 05:09 PM
6sn7gt?
Old 04-15-2020, 02:28 AM
Titan1a Titan1a is offline
Welcome. I collect tombstone radios and tube color televisions.
Rick (Sparks) Ethridge
Old 04-18-2020, 01:36 PM
If resistance reads lower than designed on these old carbon comp resistors it almost always means there is something in parallel with them affecting the reading (those resistors usually aren't a problem but you could unhook an end if you're concerned), but if the resistor reads higher than specified by a percentage higher than the tolerance rating to means that the resistor has gone bad and needs to be changed...
Carbon comp resistors usually fail by increasing in resistance. And there is no way external parts in a set that is powered off can make a resistor test as a higher resistance (only lower).
Old 05-12-2020, 10:09 PM
Xdevo1973 Xdevo1973 is offline
I just finished working on mine. Check the 6SN7 vertical oscillator tube and the resistors close to it. Here’s tonight’s picture on mine.
File Type: jpeg 59C52659-EB13-43DB-B167-A2EA4D91655A.jpeg (89.8 KB, 43 views)
Old 02-22-2022, 01:29 PM
Pulled the project back out
After years of collecting dust, I've decided to give the tv another go. My earlier attempt was to replace all of the paper caps and electrolytics. I took an easy path and placed the Electrolytics physically around the chassis. The TV turned on, but had a vertical compression. I am unable to get the vertical scan to extend more than 4" or so. I have gone back in to replace the electrolytics and build a sub board to mount them. Good news, I still haven't killed the tv or myself Bad news, the vertical scan remains at about 4". I exchanged the 6sN7tubes and have the same result. I have now ordered the 8 resistors in the vertical circuit. Come this weekend, I hope to have them replaced. Attached is a pic of the current output. Any other thoughts on repairs?
Greg
Old 02-22-2022, 01:31 PM
Xdevo1973, that picture looks remarkable! grats!
Old 02-22-2022, 01:35 PM
I'll investigate B+ Voltages and Boost voltage as well....though admittedly I'm intimidated to have my hands near this with the power on ;-)
Old 02-22-2022, 03:52 PM
6SN7 very common tube. If the set uses others swap them as a test.
If the vert is small but stable its usually a high ohm resistor. To test
you can nip one wire off & test.
Replace one thing at a time the try set before moving on.
Keep filter cans were they were in the set Mount a terminal strip for them
enuf fer now
Old 02-22-2022, 04:51 PM
thanks Zeno! Definitely stable, just crushed vertically. Looking at the original picture, its almost like the crush is not linear. its crushed more at the bottom than the top?
Looks like there are a few high ohm resistors near the vertical tube. I'll check them out when the new ones arrive.
Best, Greg
