Old 12-22-2020, 02:14 AM
NewVista's Avatar
NewVista NewVista is offline
a 'Merrill-Christmas'
For a fortunate few, the Rose Parade can be seen in its full spectral glory.
For the rest, narrow spectrum compromise after 1954
Old 12-22-2020, 11:45 AM
I haven't watched it at all in at least 10 years LOL
Old 12-22-2020, 03:28 PM
NewVista's Avatar
I haven't watched it .. in .. 10 years
If you had a Merrill it would be a different story; you could watch White Christmas, filmed in VISTAVISION - 'motion picture high fidelity' - I notice VISTAVISION movies have extra vibrant colors as film was ran sideways thru special camera for larger frame format!
Old 12-24-2020, 10:00 PM
KentTeffeteller's Avatar
Gimpus Stereophilus!
If you had a Merrill it would be a different story; you could watch White Christmas, filmed in vistaVision - 'motion picture high fidelity' - I notice vistaVision movies have extra vibrant colors as film was ran sideways thru special camera for larger frame format!
But they also do not have the sound to match the picture. Perspecta fake Stereo is no match for Todd-AO, Cinerama, or 70 mm 6 track analog. Got to have the sound to go with that picture. And only a tiny few movie goers got to see VistaVision in a cinema, most saw them printed down to normal 35 mm prints in mono or Perspecta. Todd-AO and 70 mm, now that's a movie epic.
Old 12-25-2020, 09:50 PM
NewVista's Avatar
Perspecta fake Stereo .
Interestingly, in '54, the year of the Merrill, Paramount's previous to the VISTAVISION Jerry Lewis film, Artists & Models was Money from Home, which, tho not vistaVision, was in extremely rare Technicolor-3D (six strips of film!) plus 3-channel stereo! This is now in Blu-Ray, but the 3-channel soundtrack was 'lost'! Paramount, how could you?!
Old 12-27-2020, 10:45 AM
NewVista's Avatar
Originally Posted by KentTeffeteller View Post
. no match for Todd-AO .
This may be true, but VISTAVISION has better font modulation.
Old 12-22-2020, 03:58 PM
Phil Phil is offline
That would have absolutely no effect on the colors!
Old 12-22-2020, 10:11 PM
NewVista's Avatar
Given the proviso that I don't have a Merrill to evaluate the spectral-gamut of 1950's film titles that appeal, noting that White Christmas was filmed using modified 'William Fox Natural Color cameras'. If someone could "elucidate" [pun ] on this process/filmstock, I'd be curious.
Old 12-23-2020, 12:30 AM
I haven't run my CT-100 in over a month due to the color osc going off freq and returning with a 15min cycle....My 21CT55 is going strong though.
Old 12-23-2020, 06:09 AM
it's just trying to be psychedelic, man!
https://www.tmc.edu/news/wp-content/...67134_1280.png
Old 12-23-2020, 08:20 AM
NewVista's Avatar
you've gotta get it running for the season.
Old 12-23-2020, 08:51 AM
It IS working! it's just being extra colorful 1/3 of the time!
Old 12-23-2020, 11:13 AM
That isn't happening I'm about to bench my Philco TV123 and even if my bench was free the CT-100 is boxed in with a Stromberg Carlson TV10 (read that 100lb table set) and a bunch of knickknacks on it... I'd have to do a bunch of rearranging to get to it.
My RCA 21CT55 is basically a CT-100 chassis with factory sweep circuit mods to drive a 21AXP22.... the AXP has a finer dot pattern that can resolve better detail than a 15G. 15Gs have a bit of a portacolor look on details thanks to a dot pattern too course for full NTSC resolution.
So basically the 21CT55 has the same color performance and better detail and HV/focus stability than a CT-100 ever will.
Old 12-23-2020, 09:58 AM
The following link explains that the "Natural Color" camera was part of a 1920s attempt at a two-color movie process. Not really natural color at all, but in Hollywood, hype springs eternal. The camera was adapted by eliminating the physical barrier between the two color frames and turning it sideways to create the wide Vista Vision frame.
http://www.widescreenmuseum.com/widescreen/wingvv1.htm
Old 12-23-2020, 10:04 AM
Regarding the wider color gamut of the 15GP22, it was mostly wasted on the Rose Parade except for the possibility of turning the color up beyond true reproduction. The reason is that natural plant material colors are practically always within the gamut of the modern phosphors (bright and highly saturated blue-greens are not usual, foliage greens being on the yellowish side).
