Crystal radio kit, need some help figuring out how it works
Hello everyone, today my uncle brought down with him from Michigan where he lives an old Crystal kit Radio that he and his uncle (who passed away back in the late 1970s) had built together shortly before he passed away, and I'm trying to see if I can get it going for him again, it has what appears to be an old Germaniun signal diode in the radio's circuit (that acts as the "crystal" in the circuit) and the diode is unfortunately dead, and also I can't seem to figure out how the set is supposed to get power (what type of battery and what the voltage should be.)
If any of you guys recognize the radio design (if it was a design from something like an old Radio Shack magazine or some other electronics magazine from that time period) then it would be much appreciated if you could share any information with me about how this radio is supposed to work and what kinds of signal diodes could be used in this radio and what I could used as a power source if one is needed. See Pictures below. |
No battery needed. You just need a good ground, RF from an antenna, and high impedance headphones or an earphone. Those are the 4 connections it has. Power is from the rectified RF. And of course replace the bad diode if it is indeed bad.
OK, thanks. What kind of diode should I use in this thing? The original one looked like an old Germanium signal diode, like what is used in old TVs and Radios.
Yep, a germanium diode. They rectify as low as .2 Volts. (Compared to silicon .6V)
I just looked over at AES and they had 6 signal diodes listed there for sale, 3 of them of the Germanium variety (1N34A, 1N60, and 1N270) and 3 of the Silicon variety (1N4148A, 1N914, and 1N4448) and I'm curious as to which one of those would work best in this application, also I'm wondering where I might find some high impedance headphones like what this would use, or if this might even work with a high impedance speaker like the type used on the old 1920s radios used? |
BTW, I agree with Ed in TX about the diode used in crystal sets to rectify the received signal. If this diode is in fact defective (or installed backwards), of course the radio will not operate at all.
I would go with Germanium, or low voltage Shottkey diodes. You want the lowest forward voltage drop diodes you can get.
“I'm wondering where I might find some high impedance headphones like what this would use“
High impedance earphone : https://www.tubesandmore.com/product...72a919c913a972 jr |
If the diode is installed backwards, the only result should be that the audio signal polarity will be inverted.
Did anyone mention that you need a long wire antenna, like on the order of 30-50 feet? |
I have 3 top-hat style germanium signal diodes that according to my diode check on my DMM are still good, but I have no idea how to tell which way is the anode and which way is the cathode (they aren't marked.)
I used to use the aluminum window frame in my bedroom for an antenna. Worked great! Growing up in a house within a few miles of AM transmitters at 1080, 1310 ans 1480 kHz I could pick up all 3 stations mixed together at the same time. Simple crystal sets are not very selective.
I also wonder how bad the local interference will be these days from fluorescent/LED lamps, other electronic gear, etc. Not sure how different the long wire antenna interference pickup will be compared to a regular AM radio.
As to recognizing the design, it is the very simplest possible crystal radio. As pointed out, it will only pick up strong local stations. If you look on the net you will find many variants, some of which are pretty sensitive. I built quite a few crystals sets and some of the more sophisticated designs work pretty well.
