Old 05-16-2022, 07:49 PM
pac.attack76's Avatar
Stuck in the past
2019 LG 55 inch TV model 55UK6090PUA sound only. No video
Tv turns on with sound but no video. Backlight working.
Genesis does what Nintendon't
Old 05-16-2022, 08:55 PM
damen's Avatar
damen damen is offline
If there are at least 2 ribbon cables going from the T-con board to the screen, try disconnecting them one at a time and see if you then get 1/2 picture when you turn on the set.
Old 05-16-2022, 08:57 PM
Stuck in the past
I'll try it and let you know.
Old 09-04-2022, 01:17 PM
Stuck in the past
Going to open it up today and check it out. Will post what I find in a few hours.
Old 09-04-2022, 01:52 PM
Stuck in the past
2 cables run to the screen. Removed one and got this:
Old 09-05-2022, 07:07 AM
kf4rca kf4rca is offline
There was a 50+ set in the dumpster at the free public recycling bin yesterday.
(The guy who runs the place really just likes computer stuff- presumably for gold harvesting.) He throws the TV's away!
I couldn't get it out. I was thinking, where are you guys when I need you!
Ha Ha.
Old 09-06-2022, 05:41 AM
It looks like you might have a bad board or two, someone once gave me a 55" LG Plasma 3D Smart TV that would give a blank screen when powered up, and it turned out to be a bad board, I replaced it with one someone was selling on eBay that was parted out of a working set that someone broke the screen on (with a Wii controller) and its been working fine since then.
Old 11-20-2022, 07:08 AM
Do you have a vcr that you could connect to the A/V inputs to get sound?
You might be stuck on A/V inputs.
There is also a part 2 to the advance troubleshooting techniques:
https://pdfcoffee.com/qdownload/lcd-...-pdf-free.html
Old 11-20-2022, 11:10 AM
Stuck in the past
I have numerous ways of connecting to av inputs. I was using the remote changing modes but didn't get anything
Old 11-21-2022, 08:20 AM
You should be able to get audio either off air or thru A/V jacks.
I'm assuming all your PS voltages are there.
I think you have a main board failure or EEPROM corruption.
Did you read thru the Part 2 download link I sent you? There are some items that I think address your model.
Old 11-23-2022, 10:22 AM
Stuck in the past
Yes, I'm gonna perform one more test, then I'm gonna replace the board and see what happens.
