Old 03-30-2023, 11:28 AM
Another gem by the General!
After reading about the GE 14" portable in a prior thread, I pulled a somewhat interesting 9" GE portable that came out in 1957, off the to-do shelf. GE made only one year of them, model 9T001. Many of the tubes are strange as well as the CRT.
I ordered a few of the odd-ball tubes from ESRC at the time, a couple of 10C8's and 12CT8's.
The CRT's didn't last in any of these sets and were unavailable, except from GE!
Maybe some other VKer has experience with this model.
Old 03-30-2023, 01:06 PM
Is that the one with the HV lead that runs through a socket pin? If so Carl Zimm was going to trade me one for some work at one point, but I forget what happened with that. Those definitely were odd sets.
Old 03-30-2023, 02:24 PM
Yes! AndI believe that the jug is lightweight blown glass (like a 7jp4), rather than molded, like most CRT jugs.
Old 03-30-2023, 08:43 PM
It definately is! Maybe, that's the reason they couldn't be rebuilt.
Old 03-30-2023, 08:23 PM
I was there in Madison when you were discussing it with him. I thought you were going to bite.
Old 03-31-2023, 09:16 AM
I thought I was too. I may still buy that set from him yet.... It's an interesting enough set without being a small colorful metal cabinet 50s portable, and I'm a sucker for colorful 50s metal cabinet portables.
There's a Portillos Hotdog's in IIRC VillaPark or Glenn Elyn IL that's built to look like a gigantic Jukebox, among numerous radios on display and ~2-3 TVs there's one of these GEs IIRC in salmon on one of the record shelves on one of the he support beams....IIRC it's the one closest to the ordering counter, but on the side facing away. Used to frequent the place when I was a kid. I even remember the inside of their previous restraunt on that site (it was part of the previous strip mall structure and was plowed down when they updated the buildings of that strip mall).
Old 04-02-2023, 09:02 AM
I didn't bother to restore it, the CRT is too wasted! I don't think it can be rejuvenated.
Old 04-02-2023, 03:27 PM
That's too bad. I just made a similar decision on a porthole set that has a rough cabinet and several destroyed adjustable coils that Sam's doesn't list aftermarket subs for...If the cabinet was nice I'd go to the effort getting coils, and if the electronics were an easy fix I'd fix the cabinet....Both issues at once are enough to convince me to let it be someone else's problem.
Old 04-17-2023, 10:55 AM
Did you ever try to variac it? I did yesterday and the thing came right up with synced picture and sound! Granted I had to turn the brightness up to max with lots of retrace lines to get picture, but its somehow still going on all original parts.
My tester showed 10-20% emissions (near dead) at rated 4.7V heater, but bottom of good readings at 5.7V...
I'm debating whether to rejuvenate it or unwire the heater wires for the socket from the chassis and add the transformer from a brightener that I stole the base/socket from (once I figure out where I put that transformer) into the heater circuit. I definitely can't directly plug a brightener in given the 5.5KV HV connection in the base!
I think one of those methods could make it usable. Then I gotta debate whether I recap it or not... It's such a clean original I'm tempted to just stick it on a shelf and leave it as is.
Old 03-30-2023, 01:30 PM
Some good picture on this website: https://forum.retrotechnique.org/t/t...le-9t001/16416
Old 03-30-2023, 02:08 PM
Chris K Chris K is offline
OMG that's so cute! C'est magnifique!!!
Old 03-30-2023, 02:15 PM
Some discussion of this cute little set on an earlier thread:
http://www.videokarma.org/showthread...ighlight=green
Old 03-30-2023, 07:08 PM
nasadowsk's Avatar
Damn does run fast…
Anyone got a datasheet on the CRT? Pictures of the set’s internals look like typical GE build quality…
Old 03-30-2023, 07:37 PM
If I remember correctly.
https://frank.pocnet.net/sheets/093/9/9QP4.pdf
https://picclick.com/9QP4-9-Picture-...949501452.html
Last edited by jr_tech; 03-30-2023 at 07:45 PM. Reason: add second link, (not affiliated with sale)
Old 03-30-2023, 08:54 PM
I looked up the tube in the GE tube manual. The heater rating is 4.7 volts at 300ma. The heater looks a lot different than the heater in the usual B&W CRT.
I ran the heater at about 7volts to try to increase emission.
