Old 02-27-2024, 07:23 PM
pac.attack76's Avatar
Stuck in the past
1994 RCA VR528 blows fuses
On first check, I noticed the 250v 1.6a fuse was blown. Replaced with same and blew again. Noticed there was some residue in the power area where something had dropped in. Cleaned and dried. Let sit for a couple days and tried again with same type fuse. Blew again. I'm betting whatever leaked in, took something out but not sure where to start.
Genesis does what Nintendon't
Old 02-27-2024, 08:05 PM
Blast's Avatar
Blast Blast is offline
blast, blast...
Computer says I worked on 28 of those from 1995-1998. Based on serial numbers looks like build dates of mid 1994 to early 1995. About half of them repaired under warranty.
That unit was made by IVP, a joint venture of Thomson Consumer Electronics and Toshiba.
The FCC ID# is G95538194 and the service manual was titled VR528 and may also have included GE model VG4039 (although I'll bet THOSE are rare!).
My notes say that about half of those 28 had two shorted "clock diodes" that was taking out the fuse. Locations: DP026 & DP027. RCA p/n 219242 (may have been individual diodes. Or not) or 231734 (may have been a "kit" of diodes. And something else? Or not).
My cross reference says that 1N4007 may be a possible sub for the 219242, as well as ECG 125 and SK 3080.
I can't even remember the fix, the "clock diodes" or where they were even located.
But, good luck with the fix!
If you'd send some really good quality photos it might spur my memory (or the computer) further.
Old 02-27-2024, 09:03 PM
Stuck in the past
I'll get some pics up tomorrow. There's also a sticker inside indicating a power supply repair was done in 95.
Old 02-27-2024, 09:34 PM
Stuck in the past
Let me know if these work.
Old 02-29-2024, 07:46 PM
Blast's Avatar
blast, blast...
Thanks for the photos. I see DP026 and DP027. Do you?
Notice how DP027 has been "rerouted" to join another diode. That triggers a memory about a modification that may have been involved. Maybe that was part of the 231734 "kit".
So.... Are said diodes shorted?
Old 02-29-2024, 07:47 PM
Stuck in the past
Yes, I noticed those. I haven't tested yet.
