Old 12-23-2025, 05:12 PM
Heater voltages
I once read an article that stated that heater voltages should be what is listed for a specific tube if to high or to low damages or lowers the life of the tube ok it makes sense so with a 7jp4 at 6.3v is good but I find that most of the Motorola vt71 sets the heater voltage runs kind of high at least mine do 6.8-7.2v how can I get these voltages down where they should be. There is a resistor in the string that the crt is part of and all these resistors are what is listed in the schematics so these voltages should be where they supposed to be. I think these elevated voltages will prematurely ruin the 7jp4. I don’t know but maybe Motorola designed them to run the heater higher then it really should.
Old 12-23-2025, 05:43 PM
If every heater in the string is running high by the same amount, you may have high line voltage. Have you checked it? If it's high, you could increase the value of that series resistor.
Old 12-23-2025, 05:58 PM
That will be next to check line voltage although I don’t think it’s high. I wonder if the series resistor I used in these sets for the crt string if the wattage is to high I don’t know if this would make any difference. If there is a 10 watt I may have used a 25 watt
Old 12-23-2025, 08:32 PM
The wattage-rating isn't the criterion. What's its actual ohms value?
OOPs, sorry Bob. Missed your posting.
Old 12-23-2025, 08:27 PM
I made a video where I analyze the ballast and do the math. The ballast resistance is not high enough even for 117 vac line voltage.
Also the tube lineup did change over time, but for the most common TS-4J or TS-18, the two strings are not equal.
They should be about 130 and 150 ohms.
https://youtu.be/vuYYx8AXbFc?si=oAIt7oyLNbKI20Wj&t=3751
Old 12-23-2025, 09:30 PM
Motorola shows only 105 ohms in the schematic. Not sure what Timmy used.
Old 12-24-2025, 05:10 AM
I since moved to another location and the voltage has been good however the last location the voltage has been up around 124v so I should check the heater voltages on these tvs now that I’m in a different place now. Here’s what is in these sets, 105-150 20watt 37-50 10watt 22-25 20 watt 200-200 20 watt
