Commodore 1084S-D Monitor issue
Apologies if this isn't the right place to post this thread but I'm new to the forum
Picked up a Commodore 1084S-D PAL (Model 1084S-D, 240V, March 1990, Made in Korea, Daewoo chassis A-17) for £10. On power-up: badly distorted picture, RGB channels showing as separated wavy coloured outlines, present even with no source connected. Degauss not firing. Faults found on the main board
Work done:
Not sure where to go with the troubleshooting next. I'm new to CRTs as i'm more used to restoring old computers so any advice or guidance on what to try next would be massively appreciated! Thanks! Mark Last edited by Mark k; 07-16-2026 at 11:32 AM. |
It's unclear from your post what the state of things was before and after the work you did.
I'm going to assume, possibly incorrectly, that it didn't work at all when you first got it, and the wavy lines are what you got now. First thing to check is the voltages. Download the service manual and make sure you've got everything where it's expected to be. I'm also assuming you have the right equipment to do this stuff, and you know what you can and can't probe. https://crtdatabase.com/crts/commodo...odore-1084s-d2 |
