Old 07-25-2026, 11:05 AM
Jsprite7660 Jsprite7660 is offline
Seeking Help with Samsung CXD1334 Auto Shut Off Problem
Hey All,
I'm new to Videokarma and hope I'm posting to the right thread section.
I have a Samsung CXD1334 CRT/VHS combo that turns on and auto shuts down shortly after. (3-5 seconds after)
The VCR makes noise just before the shut down as tho maybe it came off track and a sensor is telling it that it's not in the right position?
I bought the service manual thinking it would have a section dedicated to sensor trouble shooting but it has nothing on that.
Can anyone start me in the right direction in trouble shooting the VCR sensors/VCR section of the Tv?
I'm a newbie with tv repair for sure, but have experience restoring tube amplifiers and tube radios, capping jobs etc.
Thanks for the help,
Jim
Old 07-25-2026, 05:06 PM
Retired Batwings Tech
Well let's hold off with the recapping and focus on the mechanicals.
3 to 5 seconds tells me that maybe the takeup reel isn't turning and the tape is spilling over, most VCR's have a monitor to for this. Tape spills out, VCR shuts down and retracts the threading posts which is often linked to the supply reel and does a rewind to pull that tape back in during the unload and this would also pull the spilled tape in leaving no evidence.
So I'd check to see if the take-up reel is actually turning smoothly and not jerking or stopping during playback. Some VCRs do have an optical means of slack-out so maybe there is a sensor and this you would need to investigate. The VCR itself can be removed from the set but you would have to figure this one out on your own.
Most of these are friction drive with a toggle gear in the middle that swings the drive tire between the left & right reels depending on the function in the moment, my money is on a bad drive tire which is normally a square cut rubber ring. In the past I've used round O-rings of similar size and thickness that are used for faucets found at a hardware store and the last one I did was some 20 years ago and is still working today.
Old 07-27-2026, 08:46 PM
Good Evening -- You don't say if there is a tape in it or not. If you are just turning it on,
With or without a tape, I'm wondering if it's a power supply problem or High Voltage
problem, and it's going over voltage and shutting down. Or low voltage has a high
load and it's shutting off.... Anyway, this may be diagnosed a little better with a
100w Bulb in series with the tv The "Dim Bulb" thing, AKA Poor Mans Variac.
If the tv stays on you might get a clue on where to go next.... You can use
100W, 150W 200W bulb.
Good Luck....
Old 07-29-2026, 10:47 AM
kf4rca kf4rca is offline
Is it the TV that shuts down, the VCR, or both? The tv should stay on even if the vcr has a problem. Do you ever get light on the screen?
Additionally the vcr drum should do a half turn or so when it powers up. This generates a pulse that tells the cpu that the scanner servo is working.
Old 07-29-2026, 10:54 AM
I'm familiar enough with this model to know it's most likely the VCR and not the TV section. Not the most robust but the TV was "better than average".
