Old 01-15-2005, 03:32 PM
krimney krimney is offline
AK Member
My First Vintage TV.....
I finally got sucked into another black hole. The house is already full of audio gear...100+ sets of speakers, receivers, amps etc. All vintage. I have read a few posts about the vintage TV's and came across one today that followed me home. I'm not sure how I did, you guys tell me.
It is a Zenith, chassis 20CC50 , Z. the pic tube has a tag that says AG23VBAP22. It is a color unit, for it's age in excellent cosmetic condition. The thrift store just picked it up today from what is probably the original owner. The lady moved to a nursing home and sold her home in an old part of town for over a half million $. My guess is it's been a daily user for many years. Picture seems good.
What can you guys tell me about this unit, what should I need to know. I plan to use a VCR to get the rest of the cable channels, should work right?
Pics to come once I get it in the house.
ken
Old 01-15-2005, 03:37 PM
Roundie or rectangular? Ahh, hell, it don't matter. You're hooked, or will be shortly. There's something about an old one-eyed monster from the Forties or early fifties..or a roundie... that says"I wanna come home w/you, mister...Please?" and you know you can't resist...-Sandy G.
Old 01-15-2005, 04:44 PM
AK Member
how do I get cable??
The unit had one of those little cylinders attached with the cable end on one end and two spade termainals on the other. The UHF strips were attached to the VHF antenna. There is also a UHF tuner terminal. I've got the cable running into my VHS. What now??
I also have a high pitched squeal that is just audible enough to be annoying. It seems to come and go.
It looks like the side panels are plastic so I guess the unit isn't that old.
Here are some pics.
Old 01-15-2005, 04:47 PM
AK Member
inside
with the back off. Lots of tubes all appear to be Zenith brand.
Old 01-15-2005, 05:14 PM
colortrakker colortrakker is offline
Thinking in color...
Can't quite tell from that angle, but it could be the EXACT model I remember from my first years. May have been from 1972, from what family said.
Good headphones make good neighbors.
Old 01-15-2005, 05:19 PM
AK Member
The VCR is working hooked up the the UHF strips. I had to connect them directly to the coaxial cable, the little adaptor doesn't seem to work.
I did some searches and it seems to date to the late 60's , early 70's.
Seems to be a bit of distortion in the pic in the top inch of the screen
Old 01-16-2005, 08:38 PM
asynchronousman's Avatar
asynchronousman asynchronousman is offline
Banned
Simple way to get cable...
Here are some pics.
You use a simple antenna distribution box, like RS used to carry under the Archer name. It has a center pair for input 300 ohm twinlead and 4 outputs the same. It is unpowered and usually had a piece of adhesive tape on it to attach it anywhere. All you need now is a 75 to 300 ohm balun to go in and you can run wires from two of the outputs for U and VHF or spend a few dollars more for a splitter instead with 300 ohm outputs. Depends on what you have lying around.
Old 01-16-2005, 08:42 PM
AK Member
So, how do I get rid of the high pitch squel?
It seems to come and go and can be irritating if the volume isn't turned up loud. I have no TV repair skills(unless they are well hidden) and NO test gear other than a Realistic Multi meter.
If I decided to part with this unit , I know it would be preferable to keep it complete. What are these things worth? Whole or parts??
Old 01-16-2005, 10:00 PM
Banned
It's something not being properly filtered from the video stage, that's my guess. Old capacitors and an out-of-spec tube are probably the culprit, but I'm not a TV repairman either. Use the VCR and one of those godawful integrateds (like the one you had on top of it ) with some of those troublesome speakers you pile up until you can figure it out.
If you ever want a SMALL TV (A REAL ONE) I have a National Panasonic AN609D 7" you can figure out. Robust CRT but needs caps and a diode or two in the PS (overvoltage to the heaters). It's an Instant On set so I could NOT let it run warm all the time like that, but it had a great picture and it's bright blue, as Matsushita was so famous for never making a dull set.
Send money, guns and lawyers and we'll smuggle it into Diefendorfer's garage without a further charge. (SP sorry I wish Bush was the other half of Anheuser some daze)..
PS somebody tell me if ~~~THIS~~~ National has anything go to with the Panasonic namesake?
Old 01-15-2005, 05:56 PM
Nice set, Ken !! Now you need a GE "Locomotive", a bakelite Admiral, or a T-54 Hallicrafters to sit on top of it. A porthole Zenith would be nice, too-kinda a son/father thing.<grin>..-Sandy G.
Old 01-15-2005, 08:50 PM
A good set, glad you saved it. The cabinet might be half plastic but the chassis is solid, one of the last of the "real" tv chassis'. Many old sets have trouble with the output from a vcr. And the noise was a Zenith trait. Hmm... told you about all I know, enjoy!
Oh, I do know one other thing. The Sams photofact is #1238, dating this to 1972. Well, I'm a '72 model, too, so I'm partial when I say its a good tv!
Old 01-15-2005, 09:02 PM
polaraman's Avatar
polaraman polaraman is offline
<--1956 300B
If you would like a photocopy of the SAMS, send me a PM with your address. Ya never will never know if you will need it.
Nice Set!!
polaraman
Old 01-16-2005, 12:45 AM
Carmine's Avatar
Carmine Carmine is offline
...enjoys spaghetti.
The distortion at the top of the screen also goes away on the cable so it must be the VCR or it's interaction with the TV.
It is. That's a problem with all old TVs & VCRs, but not with DVDs.
As to the noise, it tends to be a tube-trait, but might be more of a Zenith problem. I think it's the horizontal oscilator, oscilating. Also could be a virbration in the HV cage.
As to the term "UHF STRIPS", it seems like Zenith kept using the same antenna connections LONG after UHF became standard. So ignore the term, doesn't apply to your set.
That set looks like 1970 to me... Might be a Chromacolor I?
We in the old TV word salute you sir for saving it.
From Captain Video, 1/4/2007
Old 01-16-2005, 03:22 PM
Chad Hauris's Avatar
It depends on the DVD...some dvd's work ok on the old sets, but some have Macrovision and you get the old bending syndrome or you get lines appearing and disappearing at the top of the picture.
Chad Hauris
Old 01-16-2005, 03:30 PM
Charlie's Avatar
Charlie Charlie is offline
On Land
Nice Zenith! I recognize that model... two of my mother's sisters used to have one like it. I recall watching Forbidden Planet for the first time on one of those sets when I was a kid. There is also one of these sets in the local tv shop here. It will take me a lot of work to get to it because of all the crap that must be moved.
Looks like your set makes a pretty decent picture. Congrats! And, by the way... you'll be hooked now!
Charlie Trahan
