Breathtaking early color---missed by most people
Even though I was born in 1947 I see some of the early product information and a few artifacts that still exist, and I realize early color was amazing!! The results for the most part were outstanding!! The problem was most people weren't even aware of what was taking place right under there feet. The fact that the early color receivers cost as much as most familes annual income had some effect. But as I became aware of color at about the age of seven, I tried to get my dad to take me to tv stores any chance I could to set there with wide eyes and marvel at what I couldnt have.
[IMG] |
I had someone tell me at church about an man in the 60's that said "I don't need a color TV 'cause all my favorite shows are in black and white!"
I wonder was it the fact that color sets could be made more cheaply in the late 60's that increased the buying of sets and therefore producers were more eager to make color programs...or was it that more shows were being made in color and thus more people thought they'd get their money's worth out of the color sets? It seems like the only people who really would buy color sets in the 50's are those that had so much money that they could buy a luxurious product that most of the time would really not do any more than than the common black and white set as there were few color shows. |
As I undertsand it, the big move to color came when the sets dropped in price and improved in reliabilty AND when Disney moved to NBC in COLOR ..which was spur to justify spending the money!! And of course and 66-67 everything went into color.
In Australia, when we went into colour in 1975 ...overnight everything was in colour. The 1st of March 1975 is a date burned in my mind in bright red green and blue!!!
____________________________ ........RGBRGBRGB ...colour my world |
as one born in 1945 I remember going downtown Montgomery Alabama in 1955 to the Motorola shops where my dad worked as a set installer and repairman and watching Howdy Doody in color some afternoons on those early Motorola color sets--was thrilling for me and my brother and even at 10 marveled at the color on that show. I'm sure they had their showroom set adjusted about perfect. One of the big problems I understand was people misadjusting the color on a home set. they always had to go out and re-do the set-ups on those sets because people aould constantly screw with the color controls. There were quite a few color sets in Montgomery even then I understand between RCA and Motorola the repairmen kept pretty busy.
Probably the same with HDTV today. I first saw HDTV on a computer monitor and I was amazed at how good 1080i could look. But today, you can use an old clunky computer monitor with an HDTV tuner and get great results, so HDTV today isn't as wonderful as color was back then, but at 1080i, it comes close.
![]() Jonathan |
I saw part of the Macy's Thanksgiving Day Parade in high definition this year. The subtle difference in shades of colors and the detail showed the texture of the floats. It was almost like being there, everything except the cold weather. HDTV is great but standard definition digital is not so great. In fact it's worse than analog. The resolution is actually lower and there are many artifacts in the picture. Maybe one day everything will be in HDTV.
Just look at those channels whiz on by. - Fred Sanford |
misadjustment was a problem
except for the very early videophiles, most people with color sets would turn it on and watch the picture without making any adjustments, intensity too high hue misadjusted, black level wrong, I guess they were just happy to see color, I would guess thats one of the reasons in later manufacturers went to some form of auto-color adjustment, however I always found sets with auto-color were always a trade-off between watching a totally misadjusted picture and watching on set right on the money
[IMG] |
Problem is the stations are always fixed at 1080i or 720p even though they might be only showing SD material so you can end up with the exact same motion artifacts as if it was HD material. If they just switched to fully loaded SD format instead of a skimped HD format when they do SD it would always be perfect. They are using a bigger pipe than needed for SD and not putting enough bits thru it, rather than using a smaller pipe for perfect SD and giving it 100%. I would think that 480p would be what is needed for perfect SD but I've never seen it broadcast. |
Last night here on cable they showed a Nureyev production of the "The Nutcracker"... typical Christmas fare...but the recording was made in 1968 by the BBC.
This would make it a very early BBC colour broadcast. The colour was astounding even though it was a live broadcast from Covent Garden. The three tube cameras were clearly adjusted carefully and despite the flaring when a dancer moved too fast the images were PAL at its best ...625 lines (ie 580i) and without the red/orange tinge that seems to commonly seems to afflict NTSC from that period. (If you want to compare NTSC and PAL ..or for that matter ATSC and NTSC ...look for any gold objects ..in PAL and ATSC they are gold in NTSC they tend towards an orange color). It is great to know that the tape has been carefully preserved (there were no obvious tape problems...the picture was stable and without any obvious dropout).
1968 Bbc Color
If i'm not mistaken that's only a year after color tv started in England; I think it was 1967 they changed over from that 405 line system they'd used for years. anybody in UK feel free to correct me. (I have been known to be wrong once)
I can't verify the date of color's bow in the UK without a search (though I think you're correct), but I hasten to point out that 405 line b&w wasn't discontinued until many years later. New years day 1985 was when the old standard finally went dark IIRC. Of course anybody who knows better can correct me. Trivia: the 1972 pilot of Are You Being Served only exists today as a transfer from a black & white 405 line tape.
tvontheporch.com |
The UK introduced colour for the 1967 Wimbledon as I understand it. Of course there had been test broadcasts in the 50s of 405 line NTSC but for a variety of reasons it was never adopted as standard and the UK waited for the new 625 line service and adopted PAL (over SECAM and NTSC). The early VHS/Beta video recorders in the UK have 405 line and 625 line recording capabilty and many collectors use them to for their 405 line sets. Here is OZ we adopted 625 line from day one (1956) and adopted PAL in 1975.
It should remembered that the UK began broadcasting 405 line in August 1936, years before the US sorted out its NTSC b/w standard. And several years before much of Europe adopted a 443 line standard that the Germans used throughout WWII. Broadcasting in Berlin continued right up until the end of the war ..when the TV transmission tower was destroyed in a bombing raid.
BBC color in 1953!
[QUOTE=ceebee23]The UK introduced colour for the 1967 Wimbledon as I understand it. Of course there had been test broadcasts in the 50s of 405 line NTSC but for a variety of reasons it was never adopted as standard and the UK waited for the new 625 line service and adopted PAL (over SECAM and NTSC). The early VHS/Beta video recorders in the UK have 405 line and 625 line recording capabilty and many collectors use them to for their 405 line sets. Here is OZ we adopted 625 line from day one (1956) and adopted PAL in 1975.
This site covers the BBC TV coverage of Queen Elizabeth's coronation in June, 1953. The third paragraph refers to closed circuit experimental color tv coverage with the use of 3 color cameras. THIS IS JUNE 1953! APTS | 2 June 1953 - Coronation Day http://www.apts.org.uk/coronation.htm -Steve D.
Please visit my CT-100, CTC-5, vintage color tv site: http://www.wtv-zone.com/Stevetek/ |
The story is more than just speculation. That June day I glued myself to the family’s 16-inch Silvertone to watch the attempt. All that you could see though was live snow/noise over the Philadelphia channel reporting on the attempt. As far as I could tell, they never picked up so much as a sync pulse that day, and certainly never a hint of BBC video. I don’t remember any state-side chatter that day about a color broadcast. |
This is very interesting ....I wonder what colour system they were using.. I assume a variant of NTSC but was the final NTSC standard in place at this date ..ie June 1953? If not perhaps it was some sort of direct three colour system delivered but cable?
