Old 11-16-2006, 12:01 AM
CTC12 vertical
Old 11-16-2006, 12:25 AM
rcaman's Avatar
rcaman rcaman is offline
on my set i replaced the orange drop capacitors on that board and then all was well. steve
Old 11-16-2006, 11:28 AM
Old 11-16-2006, 11:56 AM
I had vertical issues with one of those RCA 18" hybrids-only replacing the orange drops (probably maroon) took care of the problem. In that case, with a vertical chassis, heat seemed to have killed them. I would agree though that 9 times out of 10 those caps are good. Also make sure the pots are good. I spent a good amount of time troubleshooting one set with a short verticle only to find that either the height or lin (can't recall) was burnt. It worked to a point but not fully.
Old 11-16-2006, 12:54 PM
Old 11-16-2006, 02:21 PM
blue_lateral's Avatar
Isnt there an tubular electrolytic in that circuit? No schematic in front of me right now, but I think it causes insufficient deflection if it's bad.
John
Old 11-16-2006, 03:26 PM
yep, bad orange drops do happen occasionally. Lots of times the zenith table b/w sets will have short vertical. Ive found it to be a bad (leaky) maroon drop .0068uF in the output circuit. Had this happen about 3 times already (different sets of course).
I lost vertical sweep in a CTC-16 I bought from Tim a few years back. that was caused by a shorted orange drop which in turn smoked the B+ dropping resistor to the vertical output plate. I can't remember exactly but it was something like a .1uF. Faulty mylars are indeed a rare occurance though.
Old 11-16-2006, 05:10 PM
Old 11-16-2006, 06:33 PM
Varistor. 1480v 15% 10ma. RCA # 112876
Old 11-16-2006, 07:50 PM
Old 11-18-2006, 03:06 PM
Bobby Brady Bobby Brady is offline
Banned
Chester Electronics in Largo, Fla
Originally Posted by andy
I wonder where I could find something like that? Any ideas on substitues?
had some old stuff like varistors for sets but I won't be likely to visit there for a month or so.
Old 11-17-2006, 11:20 AM
Old 11-17-2006, 08:49 PM
fujifrontier's Avatar
fujifrontier fujifrontier is offline
roundie not so n00b
hmm. how can you determine the amount of hours on the chassis?
Old 11-17-2006, 10:16 PM
Old 11-17-2006, 10:33 PM
roundie not so n00b
Oh. I see. I wasn't asking it as a smartass question BTW.
