Old 12-12-2006, 10:04 PM
Fisherdude's Avatar
Fisherdude Fisherdude is offline
The Golden Age of Hi-Fi
In case you don't know what "Fair to good condition" means..
Here's an example:
http://cgi.ebay.com/Hammarlund-hq-11...QQcmdZViewItem
I may be growing older, but I refuse to grow up.
Old 12-12-2006, 10:27 PM
Chad Hauris's Avatar
I would say it looks pretty nasty but likely is in fair to good condition physically once you look past the dirt/corrosion. Looks like it may have been left in an unheated barn/patio in a damp climate due to rust on the screws and would probably clean up to look pretty decent.
Chad Hauris
Old 12-13-2006, 12:37 AM
bills bills is offline
Right Wing
I think i will bid $3.00 on this item.
bill
Old 12-13-2006, 12:39 AM
radioactive's Avatar
radioactive radioactive is offline
tube gear fanatic
i'll see your $3 and raise you $5
real radios glow in the dark...
Old 12-13-2006, 07:53 AM
Fisherdude's Avatar
Holy cow! You're a lot more generous then I'd be! I'd rate it "dumpster-ready"!
The best things are:
1. $.01 starting bid.
2. $8 shipping.
At least the knobs and the s-meter (if it works) are worth that.
Old 12-13-2006, 11:56 AM
tube gear fanatic
$8 shipping ? i wonder where he came up with that.youd be lucky to ship just the knobs and meters for that price.
Old 12-13-2006, 05:56 PM
2. $8 shipping.
We have worked with units that looked MUCH worse, much rustier, but still electrically were still in good shape after replacing old caps.
Chad Hauris
Old 12-13-2006, 06:34 PM
radio63's Avatar
radio63 radio63 is offline
Still Y2K Compliant!
The opening bid is very fair. It will get bid up to whatever the market will bear for this set in this condition. Might make a good parts set for someone who already has one of these units, or else it will be an interesting challenge for a restorer.
Gilbert
Old 12-13-2006, 06:36 PM
Fisherdude's Avatar
I don't know where he got that shipping number, either. You couldn't send a tube receiver across the street for that.
Old 12-14-2006, 03:25 AM
doctorbongo's Avatar
doctorbongo doctorbongo is offline
AK Member
very fair?
Gilbert
So you think an opening bid of one penny is fair?
Jeez, fellas, back off on the accelerator a bit.
a) there's a photo, so you can see what you are getting.
b) the dude selling it, at 8.01, would be LOSING cash on shipping.
c) nobody is armtwisting. click somewhere else on your monitor, and the unit disappears.
However, I believe the original point was valid: fair means poor.
Just as semantic migration (and grade inflation) have pushed
mediocre to mean lousy, when it used to mean average.
Plus, for a lot of us on this site, we wouldn't know what "good as new"
means, considering we haven't bought anything new in a coupla decades.
Old 12-13-2006, 06:39 AM
I wouldn't waste my time...these are reasonably common, they come up on You-Know-Where frequently, there's liable to be one next week that doesn't have quite so many "issues"..Besides, this is an alright set,but... The Hammarlunds to get are the HQ-129, 145, 180, & the SP series, especially the SP-600. It was considered as "Annapurna" to the R-390As being "Everest".
Old 12-13-2006, 09:08 PM
Fisherdude's Avatar
Oh, I dunno. My 120X is pretty hot on the bcb.
Old 12-13-2006, 10:06 PM
Right Wing
I guess my bid was too high they ended auction??????????????????
Oh well I did not need another project. ( my esnipe bid was for $50.00)
bill
Old 12-14-2006, 01:20 PM
I wonder what the seller meant when he said he couldn't test the receiver beyond plugging it in and seeing that it powers on and the clock works because he "doesn't have the experience", etc. to test it further than that. How much experience is necessary to connect a piece of wire to the antenna terminal and check for reception on at least one band? I could see his reluctance to test it if there were some sort of problem with the line cord (e.g. dry rotted) or a short in the power supply that would blow a fuse or worse (the so-called "smoke test"), but if he is willing to test it as far as seeing that it powers up and that the clock is in working condition, I would have thought he would have been ready to find out if it received signals, if nothing else. Heck, he wouldn't have had to connect a wire to the antenna terminal; if there was at least one reasonably strong AM broadcast station in his area, a finger on the terminal would likely bring in enough of a signal to prove that the set worked at least that well.
The condition of the receiver could have been a factor as well. The seller may have thought that, since it looked so terrible from the outside, there may have been who only knows what internal damage to the chassis (corrosion, etc.) so rather than risk causing even more damage or starting a fire, he may well have decided just to run the basic power-on test and leave it at that. I've seen many ebay listings which stated that an old radio, TV, etc. being offered for auction has only been tested this far as well, because the owner was afraid of getting shocked from a dry-rotted cord or a hot chassis. Without knowing the seller or his circumstances, not to mention how much knowledge of electronics he may or may not have, it is almost impossible to know why he stopped where he did as far as his testing of the set was concerned.
Old 12-14-2006, 07:23 PM
Fisherdude's Avatar
Originally Posted by Jeffhs
I wonder what the seller meant when he said he couldn't test the receiver beyond plugging it in and seeing that it powers on and the clock works because he "doesn't have the experience", etc...
It's pretty much a given on eBay that the words "untested" means "tested, and it doesn't work."
