Old 02-23-2007, 09:17 AM
roundscreen roundscreen is offline
Zenith H500
Figured you radio guys would like to see this 1951 Zenith H500.
She is in rough shape but this set does work.
This is the first one I have seen in person and is really cool looking.
Sorry about the cheezy knobs.
Old 02-23-2007, 10:16 AM
jpdylon's Avatar
jpdylon jpdylon is offline
<-- sucker for old sets.
Oooh, a transoceanic, with a wavemagnet none the less!
That's a good find. Those are disappearing daily.
Jordan
Old 03-13-2007, 09:24 PM
ddelu ddelu is offline
AK Member
Transoceanics
I'll have to admit I was a Zenith transoceanic junkie at one time. I have about four restored tube models and three solid state models. Guess I'll have to clean out the closet one of these days. They all worked when I stored them. Now I'm tempted to pull them all out and plug them in.
Old 03-13-2007, 09:50 PM
Nice radio. There are still many TOs floating around. I own more than a dozen, from the earliest Clipper to the last solid-state model.
If you don't already have it, you can download a schematic & owner's manual from:
http://www.transoceanic.nostalgiaair.org/
You should replace the old capacitors for safe and reliable service:
http://antiqueradio.org/recap.htm
For correct knobs, check with Alan Jesperson, http://www.gn4radios.com/ . He's a Zenith guy and may have a junker/parts set lying around, or be able to supply reproductions.
Phil Nelson
Phil's Old Radios
Old 03-14-2007, 07:51 AM
Phil Nelson
Phil's Old Radios
Thank you for the info. Was careful and used the variac when I turned it on.
Ed
Old 03-16-2007, 02:03 AM
You did well
I had a T/O exactly like yours about 25 years ago, though mine had chassis #5H40 (1951 vintage). Picked it up at a local hamfest for $25 or so. It worked at the time (wonderful AM and even SW reception using only the built-in whip antenna), but the cabinet was in terrible shape (falling apart, covering coming off in spots, etc). I finally got rid of it some time in the '80s (some time before I discovered AK--I didn't even get involved with the Internet until mid-1997), thinking that I wouldn't be able to find tubes for it if I kept it any length of time; those 1- and three-volt battery radio tubes were becoming scarce by then. Should have held on to it; it would be a classic by now. A true masterpiece of engineering and design by the former Zenith Radio Corporation of Chicago. (I have an early solid-state T/O, Zenith's Royal 1000-1, that I have absolutely no intention of giving up any time soon; it's built like a tank and works great even now, 49 years after its introduction, even though the dial cord snapped several months ago).
BTW, you should be able to find a set of original knobs for your T/O without much trouble. I see that style of knob (and even the brass "brights" inserts for them) on ebay every now and then, so if you keep your eyes open you should find some eventually. If push comes to shove, you could get a junker H500 and use the knobs from it; this would be a good investment for parts alone, including spare tubes. With an original parts source like that, you can keep your set working, not to mention 100-percent original, for a long time.
Good luck. They don't make them like your H500 (or the Royal series solid-state T/Os) anymore.
Old 03-16-2007, 08:54 AM
You are right, Zenith sets are built like a tank. Cleaned the controls and switches, Did a soft start, And she plays perfect even with the orig caps in it.
First thing I will do is the recap and then hunt for a parts set. Also I am going to put up an outside antenna. The built in antenna in the zenith works fine but will still need one for the Grundig radios.
Took a look at the Zenith Royal 1000-1 and that is a cool radio you have.
Again,Thank you for the info guys, The tube heaters in the zenith H 500 can burn out if hit with a surge on start up and I did not know that. Could have made a fatal mistake with out the proper info.
Ed
