Old 07-28-2007, 12:23 PM
Need help with reading date code on GE tubes
Hi, I have 3 GE tubes (6CA4, 6BQ5, 12AV6) with a date code of 188-21 stamped on them. Can someone tell me how to read this particular type of date code? These came from an Audiotronics 300C classroom phonograph that I'm trying to date. The serial number is 184501.
I also have a couple of later model GE tube radios that use similar date codes on the tubes. One of the radios has a transistorized tuner and the rest is tubes.
Thanks for your help,
Old 07-28-2007, 08:36 PM
Tom Bavis's Avatar
Audiophool
188 is the code for GE - the remainder isn't enough to be a date code, which is usually 3 or 4 digits. Look at pots, electrolytics, transformers for a 6-7 digit code. If they are original tubes, any component's date code will do.
Old 07-28-2007, 09:02 PM
Thanks, I'll check on that.
