Old 09-29-2007, 03:44 PM
freakaftr8's Avatar
Convergence freak!
Burnt resistor?
Well, I think I might have overlooked this the first time I removed the chassis from my ctc-16... What exactly would lead to the destruction of a resistor on pin 1 of the 6bk4 shunt regulator tube, it burned in two, from what I can make out it looks to be a 1000 ohm resistor, but cannot make out the tolerance... this is the fed +400 v supply.. Im in the midst of replacing all the lytics in the cans.. Do you guys know the exact for this reststor?
Old 09-30-2007, 07:51 AM
Chad Hauris's Avatar
Yes, this is a 1000 ohm resistor...This resistor is so you can calculate the 6BK4 cathode current...you can measure the voltage across it to find the current. As I remember, 0.8-1 volt is normal (usual 6Bk4 cathode current should be around 0.8-1 ma or 800-1000 microamperes)
Chad Hauris
Old 09-30-2007, 03:04 PM
freakaftr8's Avatar
Convergence freak!
Oh, does this resistor cause any operating issues, and why would it burn in two?
Old 10-12-2007, 12:11 PM
richfro richfro is offline
AK Member
Resistors usually burn up because there was too much current through them. I'd look for a shorted component (including the tube) in the associated circuitry. When you finally replace it, make sure you use one of the same wattage.
Rich
