Old 01-27-2008, 12:51 PM
edison64's Avatar
edison64 edison64 is offline
THE A-1 WIRELESS MAN
Location: NW INDIANA THE MAPLE CITY LA PORTE (GO SLICERS)
Jackson 637 Dynamic Tube Tester
Hello: sorry if this is the wrong forum to put this, but it doesnt fit any whwer else.
I am in urgent need of a schematic for a JACKSON MOD# 637 dynamic tube tester. I have used this tester for about 15 years, it's like new. the problem is, it stoped testing tubes, no heater voltage, only on some tubes, then nearly all tubes. but heater v ok on all sockets and trans. cleaned all push buttons, still the same,weird ??? any ideas? its really packed and cramped on space so a schematic is a must. any updated tube data would also be great. thanks for your help.
RCA VICTOR and its dealers bring you......
Old 01-27-2008, 01:35 PM
If you have heater voltage at the socket (with a multimeter probe) but the tube doesn't light up, it sounds as if the socket contacts are loose. I have a B&K 667 tube tester with that problem.
Old 01-27-2008, 01:38 PM
Here is a site that lists the manual and schematic for your tester, and also test data:
http://www.agtannenbaum.com/j_cat.html
Old 01-27-2008, 02:23 PM
edison64's Avatar
Thanks Chris, I checked his site, many times, !!!! cant beleive I missed it.
Old 01-27-2008, 02:58 PM
refill233's Avatar
refill233 refill233 is offline
VK Member
I have one for a Jackson 637 that is stained up some . I copied it below if you can use it.
Don
File Type: jpg JACKSON 637 (1269 x 1744) (437 x 600).jpg (97.2 KB, 18 views)
Old 08-26-2012, 05:32 PM
uptown1 uptown1 is offline
I'm in need of this Jackson 637 manual as well.
I realize this is an old post but I'm hoping someone can post it here again.
Thanks,
Mauro
Old 08-27-2012, 06:32 PM
edison64's Avatar
I should be able to send you a scan can you send me an email through the PM
Old 08-28-2012, 02:47 AM
Here is a fixed link to the site I posted four years ago:
http://agtannenbaum.com/j_cat.htm
Old 09-01-2012, 05:57 PM
PM sent.
Thanks.
