Old 05-23-2008, 09:20 PM
radio nut's Avatar
radio nut radio nut is offline
Born in the wrong decade
Question to unplug or not to unplug
Since my crosley had a flyback fire it leads me to a question. I was given a 1978 Wards color tv, it runs well, am I wrong in unplugging the set when I am done with it? The set sits in my finished basement and if it would catch fire it could do serious damage before anyone knew about it. Thanks, Doug.
Old 05-23-2008, 09:38 PM
dtuomi's Avatar
dtuomi dtuomi is offline
Any equipment I have that I'm leaving off for any duration longer than a couple of days I unplug. That goes for modern equipment as well as the old stuff. The reason for the modern equipment is that it tends to be wasteful of power, with indicator lights and all sorts of weird power sucking behavior. Older equipment (especially tube based) is unplugged for fire safety, etc or the power sucking of "instant start" equipment.
David
Old 05-23-2008, 09:42 PM
Dan Starnes's Avatar
Gizmo Nut
I only have my vintage radios, TV's and stereo's plugged in during use. Once turned off, I promptly unplug them. Always have and always will do it that way.
Dan
Old 05-23-2008, 09:59 PM
MRX37 MRX37 is offline
Probably wouldn't be a bad idea.
Get an outlet strip with a switch on it. They're nice and cheap, and the switch cuts off the juice to the plugs.
Old 05-23-2008, 10:40 PM
Gizmo Nut
Yeah, I have several outlet strips and just switch them off when I leave the room. Or when done, very easy.
Dan
Old 05-23-2008, 10:45 PM
3Guncolor 3Guncolor is offline
I vote for unpluging or using a power strip with on / off switch.
Old 05-23-2008, 11:06 PM
Old 05-23-2008, 11:33 PM
Installing a network of powerline operated smoke alarms would be a good idea as well.
Old 05-24-2008, 08:37 AM
Chad Hauris's Avatar
In any old equipment I like to make sure I put a fuse between the power line and any thing else in the circuit (if one is not already there), that way if there is any kind of short, even like in the power switch or something, you're protected.
Chad Hauris
Old 05-24-2008, 10:42 AM
peverett peverett is offline
I use the outlet strip mentioned by MRX37. However, this is mainly to save the mechanical on/off switch in the set, not to prevent fires. I turn the set switch on, then turn the outlet strip on. This way, hopefully, there will be no arcing in the sets on/off switch as contact is already made.
I also install fuses as mentioned by Chad.
Old 05-24-2008, 11:44 AM
Old1625's Avatar
Old1625 Old1625 is offline
Here's another vote for unplugging or using an outlet strip.
Old 05-24-2008, 01:07 PM
Adam's Avatar
Adam Adam is offline
I plug everything into those strips and switch them off whenever I go out.
Old 05-24-2008, 08:57 PM
compucat's Avatar
compucat compucat is offline
1949 Motorola 9VT1
My restored daily use sets remain plugged in as they did when new without any problems. My display shelf with working radios and TVs get turned off by the power strip switch when not in use.
Old 05-24-2008, 11:54 PM
truetone36's Avatar
electronics packrat
All of my stuff is on power strips since a 21" Admiral nearly caught fire in my living room a few years ago.
Old 05-25-2008, 10:56 AM
larschr's Avatar
larschr larschr is offline
TeeVee collector
If the equipment has a 2 pole power switch as the first connection point for the power cord, i leave it plugged in.
