Old 08-02-2004, 12:16 PM
mbates14 mbates14 is offline
it has a .djvu file extension on your site. What are these? I cant view them
Old 08-02-2004, 12:19 PM
Charlie's Avatar
Charlie Charlie is offline
On Land
Originally posted by mbates14
I cant read the notes, it looks like doctors writing to me.
Typical hen-scratch, huh? That sucks... it might be some good useful info. Do you have a doctor in the family? He/she might be able to break the code for ya!
Charlie Trahan
Old 08-02-2004, 12:28 PM
lol.
ill try to read most of it I can. (hence broken english)
Old 08-02-2004, 12:35 PM
here ya go, something about the wire connections.
Old 08-02-2004, 12:42 PM
Tom Bavis's Avatar
Audiophool
I should have put a note on my page that you need a browser plug-in to read DjVu files - there's a link on my home page. I attempted to edit the page and destroyed all lthe links... I'll fix it when I get home - I fixed the link for the 42-390, so it should be OK if you run the DjVu plug-in first. If you have the latest version of Irfanview (3.91), it also handles DjVu files.
If you can't get it to work, I can send it as a zip file or pdf.
Old 08-02-2004, 12:45 PM
Charlie's Avatar
On Land
Hmm... looks like...
red xxxx, orange, yellow--> on osc coil for SW
brown jumper on FM xxxx xxx coil
That's the best i could do. Sometimes, servicemen would make notes on a chassis as to the Sams or Riders page number for the schematics. That's what i had hoped for.
Charlie Trahan
Old 08-02-2004, 01:40 PM
so basically what that decodes to, is I have to move wires around for each band?? What are all of those pushbuttons in the front. That gets me.
Old 08-02-2004, 01:41 PM
im reading "on fm ant rf coil cd"
Old 08-02-2004, 01:43 PM
I know how you screwed you links up.
they are pointing to your IE cache directory.
Old 08-02-2004, 03:59 PM
I know its not gonna take much to get this beast working.
That schematic and stuff is right down to the tee. Thanks!
anyway, according to the schematic, If i pull the rectifier tube, the B+ is cut off, so I dont have to worry about shorting.
I pulled out the rectifier, and plugged it in.
to my surprise, BOTH pilet lights work, and all the tube filiments are lighting.
so right there, its not going to take much.
Anyway, the rectifier tube is no where near original, its been replaced. I can tell. all the tubes are philco brand, and this on is tung-sol black base. I think it had died before.
Imma check the transformer windings for AC volts going to the rect plates under power while the tube is out, just to see if the transformer is good. Ill report back on that.
Old 08-02-2004, 04:08 PM
Charlie's Avatar
On Land
All of your buttons are presets... or it looks like at least 5 of them are. The others are band selectors. Your schematic should tell you which are which.
It looks like each preset has it's own osc coil and when you press that button, you adjust the coil to the frequency you want it to stay at. If you have 5 presets, I would guess that 2 of them are for your AM band, 2 or four SW, and the last one for FM (just guessing). Looks like the button on the far left is OFF. When you press any of the other buttons, the set come on.
Charlie Trahan
Old 08-02-2004, 04:15 PM
I took a measurement between pins 3 and 5 of the rectifier socket, (goes to both plates)
im reading about 577vac from the windings.
That indicates the power transformer is good, but is the voltage normal? seems very high.
Old 08-02-2004, 04:32 PM
I also need new dial cord, because you cannot turn the dial with the knob. You can turn the dial and string with the big wheel in the back to the capacitor.
Old 08-02-2004, 08:32 PM
Tim Tress
Guest
Posts: n/a
On the under-chassis picture., that black rectangular object next to the power transformer is a dual .01 mfd line-bypass capacitor; it should be replaced . Use 1kv or higher capacitors.
Old 08-02-2004, 08:43 PM
Reece's Avatar
Reece Reece is offline
Your voltage is probably OK as you have the rectifier out and no load on the transformer. Should drop some when the rectifier is finally working and feeding B+.
For dial cord you can use woven fishing line, readily available everywhere. If you have any missing cord tension springs, you can get a plastic box of assorted small springs from a home center like Lowe's.
Somebody has been in there before you so you want to check it out carefully. When I recap a larger set like this, I like to print out a copy of the schematic, and then trace every wire in the set one by one and mark it off with a highlighter as I go, replacing caps. When the schematic is completely highlighted, you're done. It's too easy to get lost and keep going back over the same ground without a "road map."
Tom is right on that 6X5. Belt and suspenders: I'd put both a line fuse and one in the cathode circuit of the 6X5 so if it shorts it won't take your transformer with it.
Good luck with it,
Reece
Reece
