Old 09-04-2008, 07:28 PM
jln1966 jln1966 is offline
resistor question
I have a radio I believe may need a resistor replaced. Antique radio supply has all the values in this amp except the suspect one. It is a 3.9 ohm. The closest value to that they have is 3.3 or 4.7 ohm. Would either one of those work? What is the best way to check a resistor to see if it is bad?
John
Old 09-04-2008, 07:59 PM
radioactive's Avatar
radioactive radioactive is offline
tube gear fanatic
John
with a ohm meter
that should be fine if its within 1percent as the original is probally 5 percent.btw you will have to clip one lead of the resistor in questionbefore you test it .
real radios glow in the dark...
Old 09-04-2008, 08:12 PM
thedruid's Avatar
thedruid thedruid is offline
Greetings Earthlings
Actually 3.3 ohms is a little more than a 15% variation from a 3.9 ohm resistor.
A quick Google search shows that one of our sponsors, Parts Express, carries 1/2 & 1W flameproof and 5W wirewound 3.9 ohm resistors.
http://www.partsexpress.com/webpage....ID=3&x=11&y=11
Steve
Old 09-04-2008, 08:39 PM
tube gear fanatic
oops sorry my maths a bit off tonight.
Old 09-05-2008, 06:28 PM
gadget73's Avatar
gadget73 gadget73 is offline
Most of those old resistors were 10% tolerance originally. Depending on the specific spot in the circuit, you may be able to vary this value pretty far without it mattering much. 3.9 ohms is awful low, whats it doing exactly? If you're not sure, maybe a schematic would be of assistance.
Also, unless the resistor is burned, or out of tolerance with the ohm meter, I wouldn't even bother with it. I actually use 20% as my personal guideline for replacement, and in many cases radios have been seen working with stuff way beyond 20%.
Random bits of stuff in the collection:
Yamaha YP-D4 turntable with B&O MMC 10E cart
Allied 495 receiver
2 Magnavox amps, AMP150 and an AMP178, currently under the knife.
Onkyo TX-4500
Onkyo Radian III speakers
