Old 03-22-2009, 09:21 PM
radio nut's Avatar
radio nut radio nut is offline
Born in the wrong decade
10kp7a crt
I had mentioned a while back that fair radio in Lima, OH. had some crt's. I did make a list of regular picture tubes. The rest were military surplus. I have found out that pretty much those were scope or radar tubes.There are some (10kp7a) as an ex. that test fine on my tester if I set it up for a 10bp4a. I am curious, would this be ok for a tv, or is the coating on the screen wrong? From the front it is very white. But, I will admit I do not know pretty much anything about crt's. I have been into old radios for years but started on tv's fairly recently. Also, can someone help me identify a 16 inch round crt that has metal on the sides and is glass on the front and neck? Thanks!
Old 03-22-2009, 09:37 PM
David Roper's Avatar
console lover
there are two phosphors, a quick one that's bluish and a long one that's yellow which takes a long time to extinguish once excited. They make poor TV CRTs.
Old 03-22-2009, 09:38 PM
electroking's Avatar
a- v- karma member
The P7 suffix indicates a radar screen with a blue-white fluorescence, instead
of white for a standard P4 television tube. Other people more familiar with
radar CRTs will tell you more about the use of such a tube in a TV. See this
link for an extensive table of CRT phosphors:
http://amfone.net/Amforum/index.php?...0;attach=10886
Old 03-22-2009, 11:31 PM
Steve K Steve K is offline
David is correct in that they don't work all that well for TV viewing, they produce a somewhat odd looking image. However, I use a 7JP7 as a test CRT for electrostatic sets and it works well for that purpose. Using that tube as a test results in less handling of the good P4 tube.
Steve
