Old 03-29-2009, 02:47 PM
radio nut's Avatar
radio nut radio nut is offline
Born in the wrong decade
Question value question
Alot of people like to run the old radios or televisions on a variac to keep the voltage where it should be.I mounted high wattage resistors on the bottom of the wooden plate that holds the chassis and now the voltage going to the set is exactly what the diagram calls for. They were too big to fit under the chassis itself.I also mounted a AC line interference filter there too. I play this radio a few hours every weekday and maybe 16 hours on the weekend. Did I ruin the value of the set?
Old 03-29-2009, 08:06 PM
jeyurkon's Avatar
jeyurkon jeyurkon is offline
I would guess that it depends on the radio. Probably not, unless it catches fire.
John
Old 03-29-2009, 09:33 PM
radio nut's Avatar
John
Yeah I know, leave well enough alone! I just felt with the amount of time this radio would be on it would be better for it.
Old 03-30-2009, 02:10 PM
toxcrusadr's Avatar
toxcrusadr toxcrusadr is offline
As long as the change is reversible it should be fine.
They say you can drop voltage with a capacitor w/o producing heat, although I've never tried it.
Summer's here and the time is right.
