Old 06-08-2009, 08:48 PM
alexkerhead's Avatar
alexkerhead alexkerhead is offline
To High For Infinity
SABA Automatic Stereo 300/11 Project
I got this one last year, and put it up in the shop. I got it down tonight, and used my redneck variac(light bulb inline on an extension cord) and brought it up. When I got to 120V(outlet), it worked perfectly, the needles started moving when I went into auto mode, the tuning meter(coolest I have ever seen) started slapping together when i tuned in stations and the sound was nothing short of jaw-dropping for an all-in-one.
Then, 10 minutes into play, the fuse blew, so I assumed the fuse was just old and worn. I put in the correct value fuse, and tried it again. Worked, then a minute later, smoke came from the bottom(not near the transformer thankfully) and the new fuse blew, so I shut it off as quick as possible.
During that minute though, the sound was a little weaker than before.
I am afraid I am in over my head with this one, the complexity is above my head, because I can barely recap and repair a AM-only set.
Has anyone ever had experience with this one? If so, I would really appreciate some suggestions.
This will be my weekend project next weekend, and I would like to get this one proper, because it is such a fantastic unit. All the tubes say "made in Great Britain".
Here are some pics I took.
Old 06-10-2009, 06:34 AM
jeffsod jeffsod is offline
AK Member
Saba made some fine sounding table radios and that one is surely worth taking on. I don't really know enough to guide you through it myself. Hopefully someone will chime in.
Old 06-10-2009, 10:03 AM
mashaffer's Avatar
mashaffer mashaffer is offline
AK Member
In a situation like this I would see if I could find the source of the magic smoke and see what I could learn from that. The obvious suspects are bad coupling caps throwing the bias of and cooking plate or cathode resistors. If you can find out what got hot and what the surrounding circuitry is you will be on your way toward diagnosis.
mike
Old 06-10-2009, 12:41 PM
ianj ianj is offline
What a fantastic radio--Saba were the Rolls Royce of radio in Europe..............I own a freiburg 125 stereo vollautomatic model...ianj
Old 06-11-2009, 01:24 AM
Thanks for the replies guys! And for the info Mike!
Hopefully someone with one of these will chime in sometime.
Old 06-11-2009, 09:27 AM
mashaffer's Avatar
AK Member
Be sure and shoot us a gut shot when you get her opened up.
mike
Old 06-12-2009, 05:51 AM
anden anden is offline
The biggest of the good Genman sets sure did have as you put it, 'jaw dropping' sound - they redifine the meaning of table radio. Saba was pretty much at the top among these. Good luck with yours.
I foolishly passed on a 300 this spring at a radio show....now I'm thinking I'll look for the 400 which I believe has six speakers !
Old 07-28-2009, 06:53 AM
kg8lb kg8lb is offline
AK Member
I just picked up a very CLEAN SABA 400/11 Automatic. Still has the embossed hang tag on it. Don't know why I picked it up other than it is in very nice shape and a quite handsome radio to boot. Don't really have any room for it here at home so I guess I will be taking it to the next flea market sale.
BTW, It plays well and sounds great. The servo system and push buttons probably need a little attention. Otherwise guite good for anything made in Germany that is 49 years old !
Old 07-28-2009, 08:19 AM
Telecolor 3007's Avatar
I love old stuff
The radio can work also on 60 Hz.? The smoke smalled bad? (like expired eggs?).
Sailor Moon
Old 07-28-2009, 06:51 PM
AK Member
I would sure like to stumble across one of these at a flea market!
Old 07-29-2009, 07:11 AM
AK Member
Delete, Radio will be parted out
Last edited by kg8lb; 07-30-2009 at 12:59 PM. Reason: The control folks have been roused
Old 07-29-2009, 07:30 AM
Oooooh, dat's PURTY !!!
Old 07-29-2009, 08:26 AM
Celt's Avatar
Celt Celt is offline
Peanut Head
Originally Posted by Telecolor 3007 View Post
The radio can work also on 60 Hz.? The smoke smelled bad? (like expired eggs?).
If you do encounter the dreaded *rotten egg smell* (sometimes along with smoke), a selenium rectifier will be the culprit.
It will be square in shape with fins like a heatsink or radiator. And yeah, make sure the power supply is good for 60Hz.
Old 07-29-2009, 08:57 AM
El Predicta El Predicta is offline
I restored one of those a year ago. Same symptoms. Problem was easy to fix-shorted diodes in the power supply. If memory serves me correctly, the originals were enclosed in a small metal box (about the same size as a box of fuses). This "box" was located at one end (not on top) of the chassis. Go for it-this is a fine radio!
Old 07-30-2009, 09:24 AM
AK Member
RIP, Lotsa good parts though.
