Old 03-07-2005, 10:12 AM
hotrod54chevy
Guest
Posts: n/a
FRANKY'S 1ST 50s TV
well,i lugged home the stereo and '54 Magnavox i got off of ebay sat the stereo lites up and WANTS to work,but seems as though she needs a good cleaning.the TV actually picks up around 4 channels with an antenna,and has a GREAT speaker...VERY LOUD i've been tinkering with it off and on for a few days and have started to get the pictures in but i cant quite get the horizontal hold to stay oh well...i'll be sure to take some pix as soon as i either find my old memory card for my digital camera or i just buy a new one
frank
Old 03-07-2005, 11:34 AM
heathkit tv
Guest
Posts: n/a
Congrats! Your problem can be probably fixed if you get one of those power converters and plug it between the set and the wall socket....those old sets sometimes don't like modern 'lecktricity.
NOT! Just joshing ya.
Anthony
Old 03-07-2005, 02:38 PM
hotrod54chevy
Guest
Posts: n/a
well,i've been able to get a solid picture for a few seconds anyway..but then the horizontal hold just decides to make me seasick so i had to quit fiddlin with it for the day..oh well
Old 03-07-2005, 06:17 PM
jstout66 jstout66 is offline
I have a 1957 RCA B&W console. Got it free but I couldn't get the horizontal to lock, so I just used it for display. Anyway... One day I had an "old time" repair guy come to the house to fix my Quasar console. As a joke I told him "Here's the set I need fixed" as I took him over to the RCA. He was amazed to see one still and he took the back off and made a slight adjustment (I saw him stick a plastic tuning tool in a coil and did a slight adjustment and the horizontal locked right in) That's been 7 years ago and that set STILL works. I guess if you can figure out where your horizontal frequency coil is on that Magnavox, maybe an adjustment will work for you too! Good luck.
Old 03-07-2005, 08:36 PM
RetroHacker RetroHacker is offline
Electronics Accumulator
Yeah - a horizontal that refuses to stay locked can sometimes be cured by adjusting the horizontal frequency a little bit. You should be able to tweak it just a little bit, and get the horizontal to lock into place and stay there, the Horiz. Hold control should not be overly touchy, and the horizontal should stay locked without drifting. If the problem gets worse as the set warms up, it could be a cap or resistor that's drifting. If twiddleing the horizontal frequency adjustment doesn't get it to snap back, there could be something more seroious, probably a failed/failing cap, or a weak horiz. oscillator tube. And, just to rule out the unbelievably simple, wiggle all tubes around a bit while the set is on, and make sure that there aren't any dirty contacts. You shouldn't see the picture change or flicker, and you shouldn't hear any clicks or static in the sound. Just don't go touching the HV rectifier tube while the set's running - you know, the big tube with the big, fat, scary looking red wire connected to the top of it, the other end connected to the side of the picture tube. If you wiggle that tube, it might wiggle you back... If you find dirty tube contacts, shut the set off, and clean the pins on the offending tube with some isopropyl alcohol, a pencil eraser, whatever. A scrap of computer paper wetted with alcohol works very well.
Actually, as long as you've got the back off, I'd suggest doing some cleaning - blowing/brushing dust off, cleaning tube contacts, removing spiders and the associated webs can cure a lot of problems, or at least make the set look nicer inside and make it smell less like burning when it's on and running. A note on cleaning tubes - as tempting as it is to spray 'em with Windex and scrub away, don't - you don't want to rub the numbers off, it'll make for one hell of a pain trying to put them back in the sockets, and it'll make you or whoever else works on the set go crazy trying to troubleshoot. Also, I'd make a chart of where the tubes go, unless the set already has one on the inside of the cabinet or on the back or something (most do). Just in case. Also be careful not to go playing with controls or dials inside the set, unless you know what you're doing, and know what the control does, if you get things too far out of whack, it will be a royal pain getting everything back right.
Hint - when working on a console, making adjustments from the back is much, much easier if you can see the screen while you're working. Prop a mirror up on a chair or something so you can see what you're doing.
Good luck, and don't electrocute yourself!
-Ian
Old 03-08-2005, 08:46 AM
hotrod54chevy
Guest
Posts: n/a
oook...the stereo that came along with the set could use AT LEAST a good cleaning and i'd like someone with more expertize to come and look at the set (why blow up a working 54 set??) so is there ANYONE in the Columbus Ohio area that anyone can reccommend for help?thanks for all your help,everyone
frank
Old 03-08-2005, 12:11 PM
Big Dave's Avatar
Big Dave Big Dave is offline
Dead from the neck up
I sent you a PM.
The world's worst TV restoration site on the entire intranoot and damn proud of it.
http://evilfurnaceman.tripod.com/tvsite
