Old 09-10-2009, 08:58 PM
'95 Toshiba W/ blinking light
First of all, I couldn't resist being the first to post in here. Now, I have a '95 Toshiba 32" set that had bad caps in the Vert. section and even before I took the chassis out it died and now the relay clicks, the red light blinks, the relay gets really hot and that's it. Any thoughts? I went ahead and did the recap and it is still just blinking. Maybe I wrecked that big I.C. in the power supply that's near by, I know heat and or static are death for those. Thanks in advance for any tips
Old 09-11-2009, 10:55 AM
Does anyone have access to Toshiba I.C. cross numbers to see if I can get a hold of an I.C. for the power supply?
Old 09-11-2009, 11:50 AM
Hello-lo-lo-o.......Crickets chirping....... "All by myself"
Old 09-11-2009, 12:08 PM
freakaftr8's Avatar
Convergence freak!
Gee Mark I wish I could help ya. The newer stuff is where I get lost. If your relay gets hot it's either a direct short and blinking led and clicking relay is a standby issue. Did you check the usual suspects like horiz out transistor for shorts and such?
Old 09-11-2009, 02:42 PM
freakaftr8's Avatar
Convergence freak!
Hey Mark.. Remember tritronics? I remember them telling me about ordering parts on a component level, check out digikey.com. I had to order some sound output IC's for a magnaxox tv/vcr/dvd combo last year.
Old 09-11-2009, 02:48 PM
Thanks Shawn, I'll check those out. I checked a lot of the stuff for shorts but not everything. I too get lost with the new stuff, hell I probably broke it.LOL
Old 09-11-2009, 08:31 PM
brokenbroken's Avatar
brokenbroken brokenbroken is offline
Have you tried unsoldering the vertical ic to see if that could have shorted when the caps went bad? I've only seen that cause a shutdown condition on projection sets not a crt set though, but just a thought on something to check.
Old 09-11-2009, 09:48 PM
Good idea, I'll check that too. Thanks!
Old 09-14-2009, 03:40 PM
Thanks guys! I tracked down some of the problems but the customer decided to get a flattie and threw out the set, I have the chassis at home. I guess I'll take the caps off that I changed and throw the rest away if no one needs it. Thanks again for the help!
Old 09-18-2009, 10:15 PM
Findm-Keepm's Avatar
Followin' the Rules...
And the numbers are?
Brian
USN RET 22YRS (Avionics/Cal)
Old 09-20-2009, 03:04 PM
I gave up on it as the owner no longer wanted it fixed, otherwise I was going to post them.
