Old 10-16-2009, 05:13 PM
finally got me a roundie
RCA, looks to be mid 60's will get pics later. Termites have had a feast so the cabinet will prob be scrapped. Got it cheap so I can play with a color chassis.
I will take measurements to see if maybe I can reproduce the wood chassis.
Old 10-16-2009, 05:35 PM
Steve Hoffman's Avatar
Steve Hoffman Steve Hoffman is offline
Mac and Roundie TV lover
Congrats!
http://www.stevehoffman.tv
Old 10-17-2009, 07:38 AM
Charlie's Avatar
Charlie Charlie is offline
On Land
Hopefully you got yourself a CTC16 or CTC20... those make awesome pictures. If the inner framework is still intact, rebuilding your wood cabinet might not be so bad. Rich (Polaraman) rebuilt the wood cabinet on a 60's Sylvania roundie a few years back and did an excellent job! Probably turned out better than it was originally!
Charlie Trahan
Old 10-17-2009, 10:35 AM
CTC16XL
termites did a number on it, I cut off the bottom where the worst of the damage was (with the live termites in it.
I will have to leave it intact for a while, maybe bag it and fill with propane?
Of course removing the back resulted in one lost screw that fell some where on the chassis.... I have tried turning it over and on its side, but nothing is coming loose. It fell over by the HV cage. I was gentle on the turning over so as not to bang it around.
I was going to pull the HOT, put it on a variac and measure the current to see if there was a chance the can caps are not shorted. ramp up slow of course.
Old 10-17-2009, 10:37 AM
pics
Old 10-17-2009, 10:41 AM
Charlie's Avatar
On Land
Wow... you've got a nice looking chassis there... still got a good shine to it! I like the 16XL's because I think the channel selector / control area is more attractive than the other 16's.
Charlie Trahan
Old 10-17-2009, 11:01 AM
Reece's Avatar
Reece Reece is offline
Not propane: could end up on the ten o'clock news. Good idea is to bag it and throw in a bunch of moth balls, seal securely. That'll get 'em.
Reece
Reece
Old 10-17-2009, 12:19 PM
batterymaker's Avatar
Repro Battery Builder
Agreed--or your TV might wind up like this:
http://www.youtube.com/watch?v=KAyuq8sDCeg
Old 10-17-2009, 09:40 PM
John Marinello's Avatar
<-- "Byron"
Don't use hydrogen & oxgen either:
http://www.youtube.com/watch?v=MMB2VR0087w
Old 10-18-2009, 11:12 PM
there is a green and yellow wire of a transformer that sits directly behind the HV cage. It get full B+. I get 12 ohms to ground from that wire (I have disconnected it at the terminal strip). I get 20 ohms between it and the other green lead from the same side of the tranny. I assume that is ok, but that maybe there is a internal short between the primary and secondary. (there is another green lead that goes to the convergence socket and ground). I unbolted the transformer to see if the short was to the case, but that was not it. Can someone confirm the resistance reading I should be getting on that green/yellow lead to ground? I am sure that is what is causing the B+ issue. The filter caps checked out fine.
Old 10-18-2009, 11:38 PM
disconnect both of the green lead for the one side (not the convergence socket side) now the B+ load is about 8k with cold filaments (resistance reading at the output of the bridge rectifier). Was 24 ohms (yikes) with the transformer in circuit.
Gonna need some help locating a replacement, figured I would ask here, and give moyers a call. I need a part number.
Its a CTC16XL, not sure what it is but its the xforer behind the HV cage. has
grn/yellow (disconnect to find short to ground)
grn (disconnect to find short to ground)
blue
red
yellow
then on the other side
Orange
blk/wht
red/blk
red/wht
red/green
green (this is connected to the chassis, I suspect it is a internal primary to secondary short causing the problem)
Old 10-19-2009, 09:53 AM
figured I would start a new thead since I now know what I have
http://www.videokarma.org/showthread.php?t=246274
