Old 05-05-2010, 03:16 AM
Question Superior Instrument Co - TV Cross-Bar Generator
I just picked this little guy up. Does anyone know anything about it or could point me to a schematic ?
I believe it generates vertical and horizontal lines for TV stations 2-6.
The tube lineup is a 7193 and a couple acorn tubes. It looks to me like they're using the 7193 as a rectifier ?!?
Old 05-06-2010, 09:35 PM
Since I can't find any info on this bugger, I've been reverse-engineering it. The 7193 is indeed used as a rectifier with the plate and grid shorted together. The other two tubes are 954 acorn types. I'm going to do a quick recap and try to fire it up. Later I'll draw up a proper schematic.
Old 05-06-2010, 11:35 PM
A quick recap got it working more or less
The vertical linearity mode seems fine. The control on the lower right sets the number of visible lines.
The horizontal mode is a bit flaky though. I tend to get diagonal lines or just one vertical line.
I guess that's about all I can do without having any proper literature. Not that I really need to use it for anything. I just like to fool around with vintage gear sometimes
Old 05-07-2010, 08:11 AM
rpm1200's Avatar
rpm1200 rpm1200 is offline
That is a neat little piece of equipment. Does it work the same on all output channels or do the patterns vary if you put it on a different channel? What do the sweep modes do versus the linearity modes?
Old 05-07-2010, 01:36 PM
It outputs either vertical or horizontal (when it's working!) bars on channels 2-6. It's pretty crude compared to more modern pattern generators.
The sweep modes puts out signals suitable for injecting either a vertical or horizontal drive signal into a defective TV set. In other words, there's no RF carrier.
Old 05-16-2010, 08:59 PM
mbear2k mbear2k is offline
I just bought one of these myself! Haven't received it yet, but would be interested in comparing notes when I do. I don't know if any documentation will come with it, but will let you know.
Old 05-17-2010, 04:26 PM
Cool. If you got the one I'm thinking of, it looks to be in really good condition.
I suspect my problem has to do with adjusting the coil accessable via a hole in the back. I've tried fiddling with it and it has some effect, but I'm working in the dark. It will be great to compare notes.
Side note - I also just picked up a SICO TV-50 genometer. Supposedly it can do bars, crosshatch and dots.
Old 05-25-2010, 11:12 AM
I will share my experiences! Yes it probably is the one you are thinking of, and the seller included the entire chopped power cord. I took some good pictures I'll share so we can compare "parts bin" components SICO may have used between runs.
If it's the one I'm thinking of, I had my eye on the genometer too...
Old 05-25-2010, 06:15 PM
A few pics of the one I picked up. There is one capacitor that looks like someone may have swapped for an odd looking, double terminaled type - but could be original. Tabs at each end test to be connected together - and looking at yours, the wiring proves that.
Old 05-25-2010, 09:21 PM
Very nice - the cabinet seems to be in excellent condition.
LOL - that's one ugly capacitor If you have trouble reading any of the values, let me know and I'll pop mine open. I hope you can get it running so we can compare outputs.
I've seen 3 genometers pop up lately. I picked up the one locally that was branded PACO. It's in the new test equipment forum.
Old 05-29-2010, 12:55 PM
peverett peverett is offline
I had wondered what those tubes with two grid caps were used for. Now I know. I have a few of those from a TV shop that I cleaned out.
Old 01-04-2022, 07:48 PM
I finally found a schematic for this so I thought I'd add it to Bob's thread. Now I can get mine going as well. My unit has never had a working bar oscillator.
Schematic and article was found in How to understand and use TV test instruments by Milton S. Kiver. Page 99 - 100
The schematic predates the use of a war surplus 7193 for the rectifer.
Old 01-06-2022, 02:26 PM
I find it interesting to see what kind of components they used to make a somewhat working piece of equipment?
I always thought, the ones that designed the products had a sense of humor.
Old 01-06-2022, 08:41 PM
Lol this. Their choice of a 954 VHF tube was total overkill. I was working on mine back in 2008 when I first got it and it turned out it was completely wiping out analog channel 6 over at my Dad's place 150 feet away with no wire attached to the RF output.
