Old 09-09-2010, 12:02 AM
Dan Schafer's Avatar
Dan Schafer Dan Schafer is offline
Danny in Cleveland
Toshiba 20AF43 Bad Tuner Connection
Hope this TV isn't too new for this forum but I've been working on this Toshiba TV model 20AF43, chassis M3M727, circa 2003. When I put pressure on the rear of the tuner to the right I loose signal. A classic bad connection. I heated up all the solder joints associated with the tuner & nearby points on the circuit board and still have the bad connection the customer complained about. The customer has been putting a weight on the input cable for tension to keep signal contact but it won't stay put. Maybe a hair-line crack in one of the foil traces on the board near the tuner? I guess an open can be anywhere there is a flex in the circuit board. Looking for any other suggestions...thanks in advance. Would anyone have a scan of the page of the service manual or in Sam's set # 4937, showing where the tuner solder connections terminate on the board. Maybe I can test for continuity & find the open. Very small close foil traces not to mention a lot of surface mount components. A Challenge for sure!
Old 09-09-2010, 05:31 PM
Reece's Avatar
Reece Reece is offline
Get a strong light and your magnifying glass and solder away! Could very well be a bad trace you have to bridge. Good idea to clip on the ohmmeter and flex the board on trace after trace. Time consuming but no other way.
Reece
